Safe heater for hobby room?
    Looking for a little advice. It's time that I get a heater for my hobby room as the weather gets colder. I'm concerned about the safety as I use lacquer paints and thinners. I do have a spray booth that is vented out a window but the smell does build up a bit in the room. The fan heaters are nice because they work fast but would they pose a safety issue? What type of heater should I get?
  • stillp
    • 8308
    • Pete
    • Rugby
    Oil-filled radiator is the safest.
    • dave
      • Nov 2012
      • 1844
      • Brussels
      I agree an oil filled radiator is the best option, with one with a thermostat you can leave on very low to keep the room from getting damp.
      I used one at my last house in the UK in my woodworking room attached to the garage, no solvents but fine dust was an issue.
      • yak face
        • Jun 2009
        • 14307
        • Tony
        Ive used oil filled rads in the past and theyre fine (until mine started leaking oil like an old MGB !) i now use a 3 bar halogen heater which seems to heat up the shed quicker than the oil rads but is still safe with all the flammable gases knocking about (from the airbrush btw , not me !) cheers tony
        • Gern
          • 9306
          Not sure a fan heater would be good. It would set up air currents which would blow all your sanding dust everywhere - especially on your painted bits.
