In this particular case, what does the PE part actually add to the fuel tank? From the photo it looks like it’s no more than a simple band around it, in which case you could probably just replace it with a bit of plastic strip of the right width.
Not so super; superglue....
Guest -
interesting about storing the stuff in the crisper drawer Dave, will give that a try myself.....I use a fibre-glass pen to clean the back of the PE, and the plastic where the PE is going to attach. The CA? Well, I use Loctite CA, and keep it in the crisper drawer of my fridge - cheaper brands work OK, but seem to lose grab quickly, so the more expensive stuff is cheaper in the long run.
DaveComment
CA glues lose performance when opened, it's a sad fact. I already had to throw away two bottles of thin fas drying ca because it lost it's power. About keeping the ca in the fridge, I did that in the past, but I read that once a bottle is opened it's not a very good idea because of condense in the bottle. CA reacts to water and can degrade faster as well.
CheersComment
Guest -
