Varnish Issue
  • Bortig the Viking
    • Mar 2019
    • 780
    Varnish Issue
    Can anyone tell me what's wrong, I sprayed a couple of coats of semi gloss black Zero paint then a coat of Zero clear and it came out like, the only description I can think of is a crackle effect, like texture. Although it's not what I wanted it actually looks quite good for my locomotive, like rough iron.
  • AlanG
    • 6296
    Was the paint totally cured before you varnished it?
    • Bortig the Viking
      • Mar 2019
      • 780
      I left it for a couple of days, my wife came up with another description, flocking.
        • 19106
        Sounds like what Alan said....where did you leave it to dry? Just thinking that if you left it in an unseated area like a garage it may not have actually dried in that period.....
        • Bortig the Viking
          • Mar 2019
          • 780
          It was inside the house in my man cave, as my wife keeps telling me it's 21 degrees C in there, that should be enough or should I wait longer, how do you know when's it's cured fully?
          • AlanG
            • 6296
            Or as i have found with Humbrol enamel paints, if they are not stirred/mixed well enough then they take forever and a day to dry.
            • Bortig the Viking
              • Mar 2019
              • 780
              How longs that?
                • 19106
                That should be plenty....Zero are lacquers aren’t they? Only other thing I can think of is that the varnish layer was a bit thick and the surface skinned over before the underlayer dried out...
                Paintguy might be our SME here.....
                • AlanG
                  • 6296
                  With some of the humbrol paints i had this happen on, it was about 3 days before it didn't feel tacky.
                    • 19106
                    Just out of interest, what were you spraying? Only asking because some resins don’t like solvent based paint....
                    • Bortig the Viking
                      • Mar 2019
                      • 780
                      So maybe I applied it a bit heavy then, got more to do so will try it again but with very light coats, to my eyes it's hard to tell when it's covered.
                        Without seeing it, this is one very likely cause. There's a technical name for it that I can never remember, but the Yanks call it "mud drying" which describes it well. Imagine a dried river bed where the soil is still damp underneath but the surface is bone dry. The top layer shrinks and hardens due to the moisture loss but the underside doesn't, causing cracks or fissures. Too much paint/clear/whatever in one go can cause this just as Tim describes.
                        The other possibility is that the solvents in the lacquer/varnish, if applied heavily, can "soak into" the paint underneath. This reactivates and expands it as the paint absorbs the solvent, often causing it to "pucker up" a bit like crocodile skin.
                        Pictures would help, but I think you may have gone a bit too much too soon.
                        • Bortig the Viking
                          • Mar 2019
                          • 780
                          I think you've nailed it, think I applied too much too quickly, oh well you learn.
