Help with using a drill to clean wheels?
  • BattleshipBob
    • 6881
    • Bob
    • Cardiff
    Evening
    After some advice, please
    I am thinking of trying to use my dremmel type (parkrise) mini drill to turn and sand down the wheels on StuG etc. I am racking my tiny brain of a way to attach the wheel onto a rod of sorts then into the drills chuck? Has anybody out there tried this.???
    Sorry it seems i am a lazy so an so its one part of the builds which is a pain and can drain my energy quite a lot
    Thanks bob
  • scottie3158
    • 14634
    • Holbeach
    Bob,
    In your dremmel you may have a shaft with a screw in the end for holding cutting discs. I have used this with a couple washers to hold it tight then this can be put in the dremmel, or a pin chuck to hold it while you work on it.
    I'm sure the other guys will have their own suggestions.
    Scottie
    • BattleshipBob
      • 6881
      • Bob
      • Cardiff
      I do Paul, good point! Got to find a way to do the outer wheel which has a fixed hub cap?
      Much appreciate the help
      Bob
      • Steve Jones
        • 6615
        Hi Bob
        These are a set of wheels I did recently. The top right one has the tyre taken off entirely. I used the como/dremmel drill with a discus shaped drill bit and gently created the groove while turning the wheel on the end of a toothpick
        • BattleshipBob
          • 6881
          • Bob
          • Cardiff
          Thanks Steve
          Just all thoses tyres lol, got some spare to practice with.
