What's on the Bench? 2021
  • minitnkr
    • 7804
    • Dayton, OH USA
    #1036
    Fixed seats & started decals.
    Cannon Co. half section completed.
    • Mini Me
      • Jun 2018
      • 10711
      #1037
      Nice Paul.........You should be happy with that. Can't hardly tell the difference between the tire racks. :thumb2:
      • PaulinKendal
        • Jul 2021
        • 1691
        • Kendal
        #1038
        I'm doing the bases for a unit of Cave Dweller Savages.
        These have been painted black, dressed with three grades of grit and some GW Stirland Mud (texture paint). Then I've painted everything white - apart from the figure recesses and base sides. Here's partway through painting in the white.
        After that I add some green, brown and black using diluted Vallejo Game Inks. It looks a right mess.
        But then, one of those lovely, transformational steps. I painted in all the flat or nearly flat surfaces in brown.. It took just a couple of hours, but afterwards the bases were transformed. Suddenly the rocks just start to look a bit more real. The ink covered up by the brown makes the ink left behind look like stone, rather than the nasty mess it did just a couple of hours earlier.
        I love the switch that models make, when they first flip from being just a bunch of plastic and glue (and grit, in this instance) to starting to look 'real'. It can be early on in a build, or right near the end. Some models do it again and again as the build progresses. And I get a real buzz wwhen it happens.
        • minitnkr
          • 7804
          • Dayton, OH USA
          #1039
          Some great castings. Will be impressive.
          • adt70hk
            • Sep 2019
            • 10551
            #1040
            [ATTACH=CONFIG]n1164770[/ATTACH]
            [ATTACH=CONFIG]n1164771[/ATTACH]
            [ATTACH=CONFIG]n1164772[/ATTACH]
            [ATTACH=CONFIG]n1164773[/ATTACH]
            Great work. Very well done.
            • Lee Drennen
              • 7738
              #1041
              This is on the bench at the moment. Updated the seat a little with some styrene and wire. I also made a instrument panel.
ID:	1164898Click image for larger version
ID:	1164899Click image for larger version
ID:	1164900Click image for larger version
ID:	1164901Click image for larger version
ID:	1164902Click image for larger version
              • Mini Me
                • Jun 2018
                • 10711
                #1042
                Lee, that is a great start.....smaller than usual but I think you are managing it very well. :thumb2: Rick H.
                • Lee Drennen
                  • 7738
                  #1043
                  Thanks Rick I was having a good day without pain in my hands
                  • Neil Merryweather
                    • Dec 2018
                    • 5349
                    • London
                    #1044
                    I've been rather absent from the forum since August due to the rather relentless nature of my new job, with very little time available for hobbies. But there has actually been something on my bench for all that time which I could have shared ,and it's only just occurred to me to do so.
                    I have been working on a private commission for a local architect during my limited spare time. It's a 1-50 model of a house he has designed and it will go on display in his shop window on our High Street. It is entirely 3D printed in PLA filament on my Ultimaker S5 and it will eventually have lights inside. It will not be painted but remain in the monotone grey, which is what architects like....
                    As you will see, I haven't tried to print it in one piece, I have made a kit of parts to enable better definition depending on the build orientation required, and to minimise the need for support structures on overhangs.
                    Hopefully it will be finished in the next couple of weeks and I can start something of my own, I'm really missing it now.
                    Hope you find it interesting.
                    cheers
                    NeilClick image for larger version
ID:	1164920Click image for larger version
ID:	1164921Click image for larger version
ID:	1164922Click image for larger version
ID:	1164923Click image for larger version
                    • scottie3158
                      • 14634
                      • Holbeach
                      #1045
                      Neil,
                      That looks excellent mate.
                      • The Smythe Meister
                        • Jan 2019
                        • 6248
                        #1046
                        Neil,
                        What he said!! :thumb2: ,
                        Andy
                        • Mini Me
                          • Jun 2018
                          • 10711
                          #1047
                          That's just about the right scale for Lee's O-gage train layout.......how big is it dimensionally Neil? Rick H.
                          • Jack L
                            • Jul 2018
                            • 1285
                            • Cheltenham
                            #1048
                            While the railway diorama has completely taken over the top floor of the house...there was just enough space on the coffee table to throw this together. Considering I'm usually a complete Scrooge until a couple of days before, I'm quite proud of myself.
                            • SteveH
                              • 1287
                              #1049
                              Its been awhile, but this is where I am with the VK4502 (p)
                              I have have tried an oil dot render a'la Rinaldi, with very little success.
                              I shall have to watch more of his 40+ You Tube films to get a better idea, and not be so rushed too!
                              He is where I am so far
                              Still on target to just finish for 311221 then get a base ready for the final finish
                              Hopefully done in the next 19 days!
                              Regards
                              Steve H
                                • 19130
                                Not unsuccessful Steve, you have generated a nice variation in the base colour there, especially on the glacis and deck.
