0.4mm plastic (round) rod
  • AlanG
    • 6296
    Trying to find 0.4mm plastic round rod. I'll need it for the Brassin BMW 801 build which, after looking at the instructions. Is a mini kit in itself.
    Any ideas guys?
  • Bortig the Viking
    • Mar 2019
    • 780
    Any ideas guys?
    Try this
    • prichrd1
      • 694
      • Conwy
      Alan,
      Plasrtuct do a 0.4 mm plastic rod - usually pack of 10 lengths.
      evilbay/amozon??
      Pipped to it by Mark!! :thumb2:
        not an exact equivalent - but try here https://slatersplastikard.com/plastikard/plasticRod.php
        • Steven000
          • Aug 2018
          • 2947
          • Steven
          • Belgium
          Just a thought,
          but if metal would work too then perhaps a guitar string might be a quick solution if a music store is closeby (B string, seller would know which brand has 0.4mm)
          Steven
          • AlanG
            • 6296
            I have wire already but it bends to easily and leaves a 'kink' in it. Found the Plastruct rod and will probably order that. Thanks guys
            • prichrd1
              • 694
              • Conwy
              Alan,
              Try solder wire - fuse wire (3 amp)? That should bend without a kink.
              Paul.
                • 19132
                If you’re still thinking of wire, go for brass or nickel silver straight wire. Easy to work with and takes crisp bends with no associated kinks or dents. It’s stocked by companies like “Eileen’s emporium”.
                Vespa188 - Nestoto merupakan situs slot gacor RTP tertinggi dan terpercaya 2024. Minimal deposit Rp 20.000 dan minimal bet 800 perak.
                Fantastic for hand rails etc....
                • Mini Me
                  • Jun 2018
                  • 10711
                  Please Note......I believe Platstruct is an ABS material and requires a different type adhesive to get it to stick together. Rick H.
                  • AlanG
                    • 6296
                    Noted thanks
