Best varnishes for tamiya acrylics?
  • itzed109
    • Mar 2022
    • 8
    Some of you might have seen my previous comment but i would like to get everything correct before i buy my equipment, so if anyone knows what the best varnish for the tamiya acrylics that would be great.
  • itzed109
    • Mar 2022
    • 8
    I was thinking the humbrol no135 satin varnish
    • Panzerwrecker
      • Mar 2022
      • 578
      • Los
      • Wales, UK
      Do you mean to mix with Tamiya acrylics or to spray over?
      • itzed109
        • Mar 2022
        • 8
        Tamiya acrylics
        • Mark1
          • Apr 2021
          • 4156
          Are you brush painting or airbrush,I don't use them but sure I heard tamiya doesn't brush very well,good in airbrush, also if your building military then you probably want matt varnish,could use satin on aircraft.if your brush painting and on a budget I would give the revell aqua a try at 2 quid a pot it's not bad stuff and can be thinned with tap water.
          • itzed109
            • Mar 2022
            • 8
            Yep im using a brush, so ill buy a sating varnish then.
            • Panzerwrecker
              • Mar 2022
              • 578
              • Los
              • Wales, UK
              I have only ever airbrushed on varnishes so can only say what works best for that method. VMS is my favourite brand but have had good results with others such as Vallejo and Tamiya clear.
              I would have thought you could use any of these well known brands via a brush once your acrylic paint has dried.
                • 19027
                I agree Los. Once dry, any hobby varnish will work over dried acrylic.
                • stillp
                  • 8224
                  • Pete
                  • Rugby
                  I use Winsor & Newton Galeria varnish. Matt, gloss, or satin, they all brush or spray nicely straight from the bottle. 250 ml is about £8 from the Range or Hobbycraft.
                  • rtfoe
                    • 9202
                    • Richard
                    • Shah Alam, Malaysia
                    For one Tamiya isn't really acrylic. I too have only applied varnish with an airbrush which lays a layer of paint over the surface and doesn't disturb the underlying paint as much as painting with a brush. I would let the paint cure for a longer period before painting the varnish with a brush.
                      • 19027
                      Over night drying is fine Richard. I do it all the time on my small lads, using both water based and oil based varnishes. Don’t confuse the poor chap Richard. Tamiya is acrylic (unless it’s the lacquer version). The difference is that It uses an acrylic binder formulated for an alcohol solvent, rather than formulated for water, that’s all
                      • Airborne01
                        • Mar 2021
                        • 4168
                        • Steve
                        • Essex
                        That's all ... ?! Duuuh, I am so fick!
                        • rtfoe
                          • 9202
                          • Richard
                          You're right Tim, it's a very weird formula for an acrylic. Perhaps that's why it's not easy to brush paint with it... takes practice. I find applying paint immediately after the first stroke peals the layer of paint off. So I've learnt to leave the first layer on for a while before the next coat. Since then decided to airbrush with it.
                          • Phoenix II
                            • Feb 2022
                            • 8
                            Edward, itzed109 Tamiya 'acrylic' is a hybrid, the carrier is primarily spirit based. Whatever you do DON'T try to wash brushes out with water, you'll finish up with quite a mess....and your brushes in the bin.
                            As Pete stillp says, Winsor & Newton Galeria varnish, available in Gloss, Matt and Satin. Should you have an art shop within a reasonable distance, that would be somewhere else you could buy.
                            Mark1 Mark, Tamiya brush out great....provided you thin them first. Rule of thumb is start with 60 / 40, thinners (Tamiya X-20) to paint, then adjust to suit.
