Help with airbrush hose / compressor: 1/4 to 1/8
  • Pressure
    • Jul 2023
    • 3
    Hello all. I have been using a truly terrible entry level airbrush, and I have upgraded to something much better, but it doesn't fit the hose I have and I'm trying to work out what hose to get, or whether to just get a decent compressor.
    The old airbrush I have is an Expo AB725. The new one is a Harder and Steenbeck Ultra.
    I got the Expo AB725 in this kit: https://www.expotools.com/acatalog/A...605.html#SID=2
    The Expo hose for the compressor and airbrush in this kit looks like it's the AB105 with 1/4 BSP Compressor Fitting.
    So - it looks to me like I need a 1/8 fitting for the H&S Ultra.
    Are there adapters for this and do they work?
    Or should I but the bullet and just get a proper compressor with an air tank, better control over PSI (my old one doesn't change much regardless of what setting it's on)?
    All advice gratefully received!
    [HEADING=2][/HEADING]
    • 18286
    You can get a hose from the scale models shop, that has 1/8 one end and 1/4 the other. He also has adapters.
    If you really want to get a new compressor, he can help you with that as well.
    Oh welcome to the forums.
    • stillp
      • 8223
      • Pete
      • Rugby
      What Ian said.
        • 19027
        Large selection here as well….
        Your compressor should be OK to start with, but you will get the best out of your airbrush with a higher specification model that allows better control of air pressure.
        Welcome from me as well…..
          • 16029
          As has been said adapters are readily available.
          A warm welcome to the forum.
          • Pressure
            • Jul 2023
            • 3
            Many thanks all. Have ordered a proper compressor from John. And thank you for the warm welcome!
            • Andy T
              • Apr 2021
              • 3239
              Welcome Paul. Good to hear you're sorted.
              There's a couple of locals on the forum so don't worry too much about all these Southerners :smiling5:
              • yak face
                • Jun 2009
                • 14072
                • Tony
                Welcome to the forum paul , and to the south yorkshire massive ( about five of us now!) cheers tony
