Removing transfers
  • Thorbrand
    • Dec 2016
    • 335
    Removing transfers
    I'm sure this has been asked before.
    Does anyone have a good way to remove transfers which have dried on to the kit? It's not covered yet with a clear coat but I have used decal fix to fix it on. It's not a huge deal but i've put a couple in the wrong place after studying the instructions again. Would like to re-apply them to the correct place so the method should leave the transfer intact.
  • stillp
    • 8222
    • Pete
    • Rugby
    Did you use Microset or Decalfix or something? Or just plain water?
    • Mr Bowcat
      • Dec 2016
      • 4659
      • Bob
      • London
      I have no idea if this would work (or damage the model) but have you tried steam, or very warm water? A little bit of heat often gets most things free.
      Si vis pacem, para bellum.
      • Thorbrand
        • Dec 2016
        • 335
        I used decalfix diluted with a bit of water so it's going to be fairly well stuck on
        • Thorbrand
          • Dec 2016
          • 335
          hmm, steam might be an option, but how to concentrate it on a small area? the transfers are over a clear gloss coat so i don't think it would ruin the paint
          • Mr Bowcat
            • Dec 2016
            • 4659
            • Bob
            • London
            I would imagine holding it above the spout of a just boiled kettle (far enough up that it wont warp the styrene) should do the trick.
            (edited to add, Bowcat accepts no responibility or liability if your model melts :smiling5.
            • stillp
              • 8222
              • Pete
              • Rugby
              I think I'd try warm water first. If there are other decals on the same part that you don't want to remove, you could give them a clear coat?
                • 18286
                I have had some success by reapplying decal fix and or decal solv to a misplaced decal. Once it lifts I give it a good spot of water and lift it off with a wet flat brush. It will need to be reused right away.
