Superfiller
    Superfiller
    Has anyone had experience mixing super glue and talcum powder to use as a seam filler? I read an article where this modeler uses this approach. He claims it works great. I wonder how easy it sands out. Can anyone shed somelight on this for me?
    Thanks in advance.
    Tom
    Have a look at this Tom.
    Video tutorial 02 - seam filling using superglue and baking powder
      It works very well with baking powder. Tippex is good too
      • yak face
        • Jun 2009
        • 14237
        • Tony
        I bought some cheap talc a while ago but havent got round to having an experiment with it yet. Its supposed to be quite good , sanding easier than just pure superglue , and quick setting too. Let us know how you get on tom, cheers tony
          Originally posted by \
          Have a look at this Tom.Video tutorial 02 - seam filling using superglue and baking powder
          Thanks for the video Laurie! I haven't attempted this process yet but now that I see what's involved I will be sure to give this a try in the near future.
          -Tom
            I shall do that Tony. Let ya know how I make out with this process.
            -Tom
            • Dave W
              • Jan 2011
              • 4713
              2 years between first and last posts?.Personally I'd just but a tube of filler.There are plenty that will do the job and they are not that expensive.
              • stona
                • Jul 2008
                • 9889
                Just to come up to date I use this system routinely for moderate to large gaps. The CA/talc combination sands more smoothly than CA/baking powder. The latter also dries almost instantaneously. Both need to be sanded before they fully cure.
                The distinct advantage over simply attempting to fill a gap with filler is that the superglue sticks to all the surface within the gap. It means that you can sometimes get away with a CA filler when otherwise you might have to insert plastic shims etc.
                Another advantage is that unlike all the model fillers I have used a home made CA based filler does not shrink.
