Krystal klear windows
    Not sure if you guys have seen this tip on how to make windows with Micro Krystal Klear glue.
    It only works on flat windows. Instead of clueing in the clear bits with it , you use a toothpick to aply a bead of the klear on the inside arround the window's edge. Then you take some more klear on the toothpick and "draw" a thin skin of klear over the opening. It actually is allot easier than is sounds.
    When dry it looks absolutely clear and the best bit is that it is not atall brittle.
    I am deffenately going to replace my windows on the Hudson with Klear ones.
    Theuns
    • 18288
    And the best bit is you can add them after you have painted.
