Making uniforms
  • scottie3158
    • 14566
    • Holbeach
    Making uniforms
    I would like to have a couple of jackets hanging/thrown on the truck. I would appreciate some pointers on how to go about making them.
    cheers
    Scottie
  • PaulTRose
    • Jun 2013
    • 7089
    • Tattooine
    New one for me
    Could you roll a thin sheet of milliput?....cut the shapes needed for jacket and sleeves and put together?......would it look natural?
    Per Ardua
      • 19104
      Thin milliput or green stuff is how I’ve seen it done before….not in my wheelhouse though, so good luck Scottie
      • pjgtech
        • Dec 2023
        • 1304
        • Peter
        • Swale Kent UK
        From my very limited use of tissue paper and pva, that method might be a contender?
        You can get quite small and detailed tarps using that method, so I don't see why you could not use it for clothes? but would be very fiddly.
        Eg: cut out tissue paper to size/shape you need, if necessary use multiple layers, fold and arrange in the way you want them to be, then apply pva and allow to dry, can then paint and/or apply washes, etc.
        You can also build up layers, so maybe do the main body first, then add arms, sleeves, legs, collars, etc?
        Might be worth a try, theres a few good YT vids on how to make tarps, so the same method would be used....
        • Neil Merryweather
          • Dec 2018
          • 5303
          • London
          I agree, the best way is just to dive in and have a go. What is there to lose?
          • wotan
            • May 2018
            • 1187
            I would use Green stuff mixed with magic sculpt. This makes a good medium to model small details at 1/35 scale. I don't think rolling out a thin sheet and cutting to shape would work well, rather get a good photo or two and sculpt the thing with the hook built in. Sculpt it horizontal on a flat surface and, when dry, simply lift and attach the hook to your final position.
            • scottie3158
              • 14566
              • Holbeach
              Thanks guys you have given me a lot to think about. I still haven't worked out how to do a multiple reply on this site.
              cheers
              Scottie
              • PaulTRose
                • Jun 2013
                • 7089
                • Tattooine
                Thats 2 of us then lol
                Per Ardua
                • Richard48
                  • 2176
                  • Richard
                  • Clacton on Sea
                  cheers
                  Scottie
                  Hi Paul.
                  Let me look through my figure stash as i know Verlinden produced some jackets and i might have some.Failing that id have a crack at sculpting something for you mate.
                  • pjgtech
                    • Dec 2023
                    • 1304
                    • Peter
                    • Swale Kent UK
                    Found these online (Fleabay) but bit pricey!!! See link:
                    • pjgtech
                      • Dec 2023
                      • 1304
                      • Peter
                      • Swale Kent UK
                      And found these, but even more expensive!!!
                      See link;
                      • scottie3158
                        scottie3158 commented
                        Editing a comment
                        Thanks Peter, your right their not cheap but it will give me a pattern to work to. Thanks for taking the time into looking.
                      • 16162
                      Some great ideas. Those rather pricey ones that Peter flagged up should give you ideas to work on. I would try thin, rolled out Milliput. I'm sure that with your skills you can achieve something very acceptable.
                      • scottie3158
                        Editing a comment
                        Thanks Jim, nothing ventured nothing gained as me old dad used to say. I will try a couple of different ways as suggested, and see what I like the best.
