Dam just out of rockets sticks. :smiling2:
Track Link Jig
Guest -
Dave, JR, Jakko, Si and Mike (Whose Pete??:smiling5
Many thanks for all your replies. There are some terrific ideas here. I have opted for Dave's answer and I have a couple of metal strips coming my way. So once arrived I will set up the jig and see how I get on:thumb2::thumb2:
Pete is your alter ego name, it was Rommel of Tunis but you changed that earlier. Matron said it's a common thing in the mentally insane, and not to worry George .Dave, JR, Jakko, Si and Mike (Whose Pete??:smiling5
Yours
Albert Einstein.
Ward 9
Bed 6
Next to Allen and Si .Comment
Evening , my order for a chopping board arrived. First thing was to test that CA didn't in fact stick to it .
Result ! Perfection, so now I have a neat sized gluing board. Next is to get the saw out and cut some section off .
Will post the completed jig when done .
John .Comment
Hi Dave thank you for the heads up on this, have just ordered one :thumb2:.
Pete.Comment
Nice find Dave, see he will make different sizes if asked. I've sent a message asking if it is affected by CA .
John .Comment
I would think a light smear of machine/ light oil would solve any problem. You can get machine oil from sewing machine/ craft shops and makes good release agent if doing an odd bit of casting.....Comment
Hi, newby here, I make the Dragonbadger jig and have sold quite a few with much positive feedback. At the model club meeting yesterday I was asked to design a jig for single links that have pins to hold them and although I thought they could be held in my current jig I've designed this, vey much a prototype and as such undersize. I don't have any of the said track links, that shown in the picture is a flexible track I printed for a 1/35 landrover conversion. Do you think they will be of use?Comment
Welcome to the forum Haydn.
Many of us use those Fruil track that have have the pin pushed through to join. Some times on the larger Fruils you can drive a pin straight through instead of drilling , now this may be a problem . Other than that something that can hold the tracks in an upright position to enable the pins to be pushed in would work as long as the links stayed together while they were grabbed by the jig .
Looking fwd to using the one I ordered from you .
John .Comment
