Since we last spoke about this adhesive some new facts have emerged worth noting here for reference-
Whilst this 'miracle' adhesive of our time has changed our model building there have been considerable improvements in the chemical properties of this range of adhesives,for the aeromodeller its main attraction is the weight saving properties it carries due to the miniscule amount needed,the very thin variety needs special care as it has very deep searching properties,in fact controlling it is the biggest problem.
A good use for cyno as we now call it for short is the practise of 'liquid pinning' this entails using ordinary conventional adhesive but spot glue between with cyno to really grab the joint and thus hold the joints while you carry on building.
Sadly the so called odourless varieties are distinctly lacking in adhesive qualities thus making it counter productive in use,perhaps the chemists are working on this to combine a lack of odour with adhesion for the future ?
Alongside the adhesives come a range of rocket accelerators and fillers,for the latter ordinary baking powder will do the trick nicely,just add the powder to the joint for extra powerful joints,this is of particular use when repairing models sometimes where a joint has become oil soaked and requires a bit of persuasion.
The spray on accelerators are handy for when holding an awkward joint is required and above all difficult to hold into place.
