Tamiya 1/35 Panzer II Colour modulation technique
    Hi all,
    I wasn't sure where to post this, it's not really under construction as it's built, but the 'painting' section didn't seem quite right & 'tutorials' is a bit above my standard! Maybe a mod can put it where it's most appropriate....
    Anyway, here's a little project I've been working on, painting Tamiya's Panzer II. This is the old 70's kit, not the new tooling, but it's a lovely little dinky model to build! I wanted to give colour modulation a real go. I've had a stab at it before, but not really in the proper stages it needs.
    In essence, the technique uses varying shades of paint to add extra highlights & create a kind of 3-D effect. It's therefore most suited to boxy vehicles like this one. That's the theory at least!
    And to anyone who isn't into armour, fair warning there's lots of pictures!
    Firstly, here's the basecoat in a very dark grey
    I then mixed a lighter grey with a touch of blue & sprayed it a la Verlinden in a 'bloom' pattern, trying to aim for the edges & flat surfaces
    After that, I lightened the mix further & sprayed this very much at the edges, concentrating on the upper surfaces & trying to get a graduated effect ( not as successful as I'd hoped! )
    Then to complete the painting stage, I masked off the main areas to allow me to add a very light blue to certain bits such as the toolbox hatches, a couple of box upper surfaces, the turret viewports & the commanders cupola
    Next will be glossing & decals and then onto the weathering.
    Thanks for looking & all comments or criticism are gratefully received.
    Patrick
    i know nothing about tanks so i`m just watching,looks like the overall effect is working though
    mobear
      Cheers Ole, I'm actually trying to replicate a build I saw in a magazine. The guy built the same tank, although his was in 1/24 scale.
      It's up for sale at $1250 but I'd be lucky to get 12.5p for mine!
        the overall effect is very promising and at the stage you're at now i can imagine how it's going to progress after getting such a decent base to work from.
        It's almost like building up your oils when painting a landscape, very effective and does increase the 3d effect somewhat.
        I'm impressed Patrick.
          Hi Patrick.
          What a great thread!! You know for me is perfect!!!
          I like very much all the work of painting and the very guessed right color.
          I was looking at his tank, and though mine is enormous, this have the half of details than the small one... I wait eagerly to see the weathering!!!
          Thank you very much Patrick for your photos and texts, they will be very useful!
          :cheeseygrin::cheeseygrin:
          The only problem is that you were a fantastic excuse to not construct mine, but now already I cannot... Your is nearly finished!!!
          :grinball1::grinball1::grinball1:
          Regards
          Polux
          • tr1ckey66
            • Mar 2009
            • 3592
            Hi Patrick
            looks a very nice clean build.
            I've always been a bit reluctant to use colour modulation as to my eye it sometimes looks a little bit extreme and the vehicle doesn't appear one colour anymore. I've sort of adopted a colour modulation technique but I'm always keen to make sure the different shades come together as a whole, calming it down with a diluted top coat of the base colour if necessary. I'll be really interested to see what results you get Patrick, the progress so far looks really good.
            All the best
            Paul
              Looking great so far, Patrick!
                Thanks for the positive comments guys! I know what you mean Paul, it's a bit of a leap of faith but i guess it's all about trying new things and seeing how they turn out! Hopefully at the end, it'll look ok.
                Got the gloss coat & decals on. I was a bit worried about the decals as they're nigh-on 40 years old but they went down ok. The turret markings are actually from my spares box. For the 1st time I airbrushed the Future & found it goes on better that way.
                This photography lark isn't easy either - these pics make the paint look very grey, when in reality it's quite bluish...
                Patrick
                  with my pc they look bluish,though if i move my head to one side its greenish then the other side its greyish,cracking job so far but cross on back is slightly off lol
                  mobear
                    Originally posted by \
                    with my pc they look bluish,though if i move my head to one side its greenish then the other side its greyish,cracking job so far but cross on back is slightly off lolmobear
                    I knew someone would spot that Ole! Flipping thing must have moved when I wasn't looking!
                      glad to be of assistance lol
                      mobear
                      • aaron
                        • Oct 2011
                        • 2019
                        WOW. And of one of my all time fave panzers.
                        This is wicked handy and useable, Thank you so much for this Patrick.
                        Just put some tamiya tape over the offending decal and rip the tape off and decal with it . Then you can add another balkenkreuz.
                        Assuming you used klear under the decal this will work.
                        Great thread i will be watching .
                          Thanks Aaron, glad to be of service! Unfortunately I don't think I have any spare balkenkreuz, plus I used micro set/sol to apply the decals which might make it harder to remove.
                          I think some mud splatters will do the trick!
                          Patrick
                          • tr1ckey66
                            • Mar 2009
                            • 3592
                            Hi Patrick
                            I wouldn't worry too much about the decals. If I were being picky the other Balkan kreuz also look a bit out of register and could have done with a bit of a trim but I don't think that's the main aim here. I like the fact you're trying new techniques, once you get the result you can see what else can be done or what can be improved and you can make the technique your own.
                            Paul
                            • aaron
                              • Oct 2011
                              • 2019
                              Mud splatters...Great idea, I didnt even notice they were off untill i read the post.
                              I really really like the early panzers, They did some fantastic stuff in the early years of the war and have some of the best stories.
