Marking panel lines can be easy enough if the surface is reasonably flat,however how do you go about it if there is a curve ? well this is how the scale modellers do it at my local club,they use dymo tape which takes the curve easily,a few scribed lines sees the job done.
Another way in tight spots is to use several layers of insulating tape to use as a build up,then a dental tool is used to scribe the lines.
