LUT 1/96
  • Bigfoot57
    • Jun 2015
    • 1141
    #16
    Update on LUT build well I'm not impressed by my completed cardboard swing arms so much so that I have scrapped them and will scratch build some new ones no idea how long this will take could be weeks will post some new pics after I've constructed the 1st one I've attached one pic showing initial construction and death by plastruct
    [ATTACH]116074.IPB[/ATTACH]
    • takeslousyphotos
      • Apr 2013
      • 3900
      #17
      That`s some seriously good scratch building Colin...... I am going to have to watch the rest of this. Looking really good.
      • Bigfoot57
        • Jun 2015
        • 1141
        #18
        Greetings Peeps
        Here's my latest update on this build not much in the way progress but at least I've finalised how to do the swing arms after scrapping 4 different ways of trying I enclose a few pics showing progress so far bear in mind this is just the rough stage so things like the floor the lighting support beams and other details still need to be added and there are 9 arms to do each with different layouts and fittings but now I have a plan in my head on how to do them and how to scratch build sort of
        Regards
        Colin
        [ATTACH]117993.IPB[/ATTACH]
        [ATTACH]117994.IPB[/ATTACH]
        [ATTACH]117995.IPB[/ATTACH]
        • eddiesolo
          • Jul 2013
          • 11193
          #19
          Great work there Colin, this is looking superb mate.
          • Bigfoot57
            • Jun 2015
            • 1141
            #20
            Latest update to swing arm 1 nearly there few more bits to do like the floor the wire mesh on the lower sections the lights which won't be lit as there going to be too small in scale the actual arm attachment and swing joints and the remaining pipe work then to finally paint it and add a few little details
            As always comments criticisms etc always welcome
            Regards
            Colin
            [ATTACH]119011.IPB[/ATTACH]
            • eddiesolo
              • Jul 2013
              • 11193
              #21
              Nice work Colin, could you use fibre optics for the lighting?
              • Bigfoot57
                • Jun 2015
                • 1141
                #22
                Eddiesolo
                Nice idea haven't thought of that the actual lights used were large industrial 500 watt or more lamps housed in 3' diameter cone shaped housings on this scale the will be about 5mm across and 3 mm deep there are 6 to each arm assembly and they hung across the centre section of the arm so there going to be real pigs to model still trying to figure out what to use but fibre optics might work will have to investigate further on that here is a drawing I made of the sort of structure required
                Regards
                Colin
                [ATTACH]119012.IPB[/ATTACH]
                • eddiesolo
                  • Jul 2013
                  • 11193
                  #23
                  2mm lighthouse Led's maybe okay but having looked at them although they are round the have a square bit at the bottom. 3mm Led's is about the smallest you could do unless you go the fibre optic route.
                  • Bigfoot57
                    • Jun 2015
                    • 1141
                    #24
                    Eddiesolo
                    Here's what I've come up with for modelling the lights on the arms quite unusual I think you'll agree the bulb is a piece of clear plastic sprue there not quite the right shape but not far off and almost to scale and besides I can make as many as I need as I have to take wafarin daily so I have hundreds of empty pill strips
                    Regards
                    Colin
                    [ATTACH]119071.IPB[/ATTACH]
                    [ATTACH]119072.IPB[/ATTACH]
                    [ATTACH]119073.IPB[/ATTACH]
                      that's a smart idea and eco friendly haha, nice job mate. The rest is looking good too
