Enterprise deflector dish sprayed painting
REVELL USS Enterprise NCC 1701 - STAR TREK into Darkness - Model Kit 1:500 04882
Guest -
GuestComment
Enterprise nacelles attached , test and light check for leaks plus positing inner hull ,prep Before spraying
Enterprise more attachment deflector dish front section lead.
Wire feed though underbelly
For stand to be attached nacelles
Buttoned down ,glued
Buttoned down ,gluedComment
Guest -
Guest -
Guest -
Arr challenges
Kit didn't take into account wireing lighting weight
Hence the balance that will be
Sorted when answer has been found
Ths has to be an external effort
As kit has been sealed if taken apart damage to lighting kit circuit board .it may have to external surport .I will see .
Arr challenges
Enterprise up date spraying in progress rear. Nacelles
Under belly and neck
Peal. White to be added top coat then decals
Guest -
Enterprise decals in progress asztec nacelles underbelly sides
%60 done. Tricky section outa way .
Enterprise decals repair
Whilst under construction decals got damaged broken removed cleaned refitted new from spare set arrr
Fingers not included side panels also fitted .
