Some of you might've followed my adventures ordering this rather expensive kit, and how it was badly bent - in fact so much that I couldn't continue with the build?
Well, Squadron isn't even bothered with replying to my requests for help (all of this is in another thread) so yesterday I sat down pondering whether to throw it in the bin or to attempt some sort of bodge to finish the build? I went for the jury rig bodge and in "parked mode" I might get away with it. Enough to complete the build anyway... Not good enough for any close inspection on the lower hull but better than tossing it away at least.
I planned to equip my Haunebu II with LED's before getting it but my current lack of enthusiasm right now isn't exactly helping the creativity flow so I thought I'd ask you instead.
The control room is fairly simple. Drill some holes, block out any unwanted lights with aluminium foil, make a PCB and add some 0603/0402 smd LED's or similar, but the outside?
The circular windows will be lit for sure, but that's not exterior lights.
It is an aircraft of sorts and regardless of SS, Luftwaffe, or a civilian Vril project, it needs some external lights and I can't see any obvious places for lights, apart from one area, but that's just a slit (see picture) and nothing else.
How would you go about adding lights to such a "aircraft"?
Here is the control room. The consoles will be lit and also the centre column, but with some sort of simulated circular motion. I did originally think about re-casting the centre column in clear resin but I've lost that level of enthusiasm. Red and green leds are of a high enough wavelength to pass through the plastic anyway.
The control room layout will be something like this, apart from general interior lights that's going to be visible through the circular windows.
The problem remains with the exterior lights. The only obvious place for exterior lights is in the slit you can see at the arrow below.
So, how would you go about adding exterior lights to such a flying contraption?
I don't want to make a Christmas tree, but I doubt the various Haunebu projects would've been without any exterior lights - albeit they could've been turned off when trying to be stealthy I guess...
I'm primarily using 0603 LED's but I might have some 0402 lying about. (I even have some 0201 perhaps?) I'm talking about LED's for surface mounting here and the numbers are the size (6x3 mm or 4x2 mm) so I can put them inside very small objects if I want to and I control their intensity with PWM (pulse width modulation) so they aren't too bright - and hot. These little LED's are very bright unless regulated!
I'm driving the whole thing with a Cortex-M0+ microcontroller (or perhaps an Atmel ATTiny 85?) so I have total control over these LED's.
I can write some sort of instruction later on how to do your own electronics if there's any interest? (I'm an electronics engineer hobbyist too)
Anyhow, if you've got some ideas on how/where to add external lights, or an opinion why I shouldn't have external lights, then please enlighten me because I'm all out of ideas... (perhaps external lights would be wrong?)
Here's the original (?) drawing.
Cheers and thanks in advance!
Jens
Jens
