AAAAHHHHHHHHHHH!!!!!!! Hello Andy, the patience are slowly fading. When i'm thinking or just having five then i'll cut some more windows out, i've been working on how to fit the lighting over the last few days, so it's hasn't come to a stand still. Nav lights are sorted (green/red) they don't flash, strope lights (top/bottom) i've got and just need to build the hull. Warp engines i think will work with the idea i have, and that came from B.M.W, if it does work then i'll have space in the warp nacelle's to fit nav lights. Yes i'm still working on it, it's just slow lol.
First things first, sit down before you fall down. Yes Voyager is back on the bench, only while i'm waiting for parts to turn up. Ordered some photo etch at £20 but well worth the money, so made some progress on the bridge section. As you can see, a lot needs to be taken off and i cut a little deep (oops!!). Once the detail has gone the plastic is very thin, so some filler was used underneath the bridge so no light would show after it's built. In the last photo you can see i started to cut the windows out the Ready Room, and (again) went too far but in the PE you get new windows (how lucky lol).
Hi all, it's looks like i havn't done much but i have (honest). The PE is now on the bridge section, i cut out holes for the Ready Room & Conference Room and fitted the PE on them too. Tested to see if light would come through where the PE meets the plastic, and all is good. Started to fit the transporter emitters by sanding the old ones off.
Neat lol I guess I should post up my1/350 USS Enterprise refit
Ahh, this is a long running project off mine. In other words, i get distracted by other builds lol, it will get finished someday though. Yes i have the 350 Enterprise too, if your's is all done get it posted up i'm sure alot would love to see it matey. I've just found out too, that Polar Lights have the original Enterprise in 1/350 scale.
