First powered flight on another world
  • adt70hk
    • Sep 2019
    • 10554
    Hi all
    In case you missed it we had the first powered flight on another WORLD this morning.
    ATB.
    The Ingenuity drone completes the first powered, controlled flight by an aircraft on another world.
  • AlanG
    • 6296
    Normally i'm all over things done on other planets/asteroids or anything to do with space. But i have to admit i was rather "Meh" over this. I sort of see how it could open up more discoveries. But it just hasn't gripped me.
      • 19135
      Think of the engineering though. Mars has a very thin atmosphere so the engineering solution used to generate sufficient lift here could increase the efficiency of terrestrial helicopters.
      • adt70hk
        • Sep 2019
        • 10554
        If I recall correctly only 0.1% as thick as Earth's. Based we're spinning at 2,400rpm. They apparently used two contra rotating blades.
        • GerryW
          • Feb 2021
          • 1757
          But how do we know that it's the first powered flight on another planet??????? It's the first terrestrial piloted powered flight on another planet, granted.
          • boatman
            • Nov 2018
            • 14600
            • christopher
            • NORFOLK UK
            YEA IM INTO anything to do with space i love it even had me own 4inh reflector telescope an it was fantastic to look at the rings of saturn in all their colours but its now got to cold to be out in the evenings to star or planet watch an an yea i missed it
            chris
            • AlanG
              • 6296
              Without going deeply into propulsion and aerodynamics. Mars also has only a 1/3 of the gravity that the earth does. So it would require vastly less 'lift' to counter the weight and gravitational effect to get airborne. High cord and counter rotating props as mentioned above plays right into this.
