Got my Seawolf set up in the test tank today - there's a total of 2lbs weight to ballast it. Glad you told me about the air valve Chris - I've had quite a job getting a good seal at the rear of the test tank - the air valve was ideal for blowing into while the sub was afloat, then I could spot where the air bubbles were from. The gasket on the WTC seems a bit of a tight fit and a lot of the elasticity has gone out of it due to stretching tight over the rim - I found that by adding a couple of thin rubber bands with the gasket really made things airtight (and more important watertight) I seem to remember some time ago reading on one of the forums that someone changed to a 90mm gasket instead of the 85mm supplied - I wonder if that worked better -
Anyway tomorrow I've just got to add the fins on the sail then I'll have to think about a colour scheme. Many thanks to all those who helped with tips and advice - much appreciated.
Ian.
[ATTACH]13421.IPB[/ATTACH]
Ian.
