Airfix 1/72 Severn Class Lifeboat
  • Bigfoot57
    • Jun 2015
    • 1143
    Click image for larger version  Name:	 Views:	0 Size:	239.5 KB ID:	1269992 Click image for larger version  Name:	 Views:	0 Size:	174.6 KB ID:	1269993 So whilst waiting for the missing kit to the U 96 to arrive I built the Airfix 1/72 scale Shannon class lifeboat which was a very good kit letdown by it’s useless decals which seemed to disintegrate as soon as they hit the water if they were Cartograph they must’ve had a bad day when they made these they were so bad that there aren’t any on the port side as regards to serial numbers because they just disintegrated into nothing so I’ve only got the starboard side and the red and yellow and white demarcation lines are made from .5 mm brass rod painted and stuck to the side of the boat
    Anyway this led onto the new construction which is the Airfix 1/72 scale Severn class lifeboat
    so the first thing I did was to wash the whole set of parts in soapy water as they have mould release agent on most of it and the paint would never have taken in the first place however it took five coats to get the depth of colour that I needed for the orange and blue so I don’t know if washing it made any difference at all
    Next off was to start constructing the main hull which was an absolutely awful fit necessitating a fair amount of filler to be added and sanded smooth before you could proceed with the painting and like I said it’s took five coats
    with this done well then started proceed to construct the rear of the boat. I don’t know what they’re called. I’d call them diving platforms Airfix didn’t bothered to tell you what they were either and that brings me to another complaint. The instructions are absolutely awful. As regards to what colour things should be painted. You have to search through the instructions further than where you are actually to get the colour of the part that you’re actually putting on at the time if that makes any sense
    Next we come to the parts and the diving platform struts are too short either by design or short shot Either way, I think I’m gonna cut those off and replace them with .5 mm brass rod at least they will be the correct length
    You may only view thumbnails in this gallery. This gallery has 10 photos.
  • Bigfoot57
    • Jun 2015
    • 1143
    Click image for larger version  Name:	IMG_5526.jpg Views:	0 Size:	385.5 KB ID:	1270008 Click image for larger version  Name:	IMG_5525.jpg Views:	0 Size:	290.9 KB ID:	1270009 Click image for larger version  Name:	IMG_5537.jpg Views:	0 Size:	346.7 KB ID:	1270007 Click image for larger version  Name:	IMG_5490.jpg Views:	0 Size:	188.7 KB ID:	1270006 Click image for larger version  Name:	IMG_5489.jpg Views:	0 Size:	174.6 KB ID:	1270005 Click image for larger version  Name:	IMG_5525.jpg Views:	0 Size:	290.9 KB ID:	1270014 Click image for larger version  Name:	IMG_5527.jpg Views:	0 Size:	372.3 KB ID:	1270010 Click image for larger version  Name:	IMG_5512.jpg Views:	0 Size:	226.0 KB ID:	1270011 Click image for larger version  Name:	IMG_5501.jpg Views:	0 Size:	209.2 KB ID:	1270012 Click image for larger version  Name:	IMG_5502.jpg Views:	0 Size:	195.8 KB ID:	1270013
    Last edited by Bigfoot57; Yesterday, 01:25. Reason: Apologies Admin please remove the thumbnails from the 1st post of this thread
    • flyjoe180
      • Jan 2012
      • 12967
      • Joe
      • Earth
      Looking good. Being a more recent release you shouldn't have any problems with the decals on this one. Was the Shannon one of those older kits with yellow in the Airfix logo?
      • Airborne01
        • Mar 2021
        • 4306
        • Steve
        • Essex
        Looking forward to seeing this in the bath!
