Hi Paul
Good progress with the hull. What type of filler do you use, Does it have to be wood filler?
I am using wood filler on some parts and a white putty on others, the reason being the putty gives off a strong odour so try and keep it to minimal
I can see that planking is something of a technique to master. Do you know of anyway to treat the planks so that they bend more naturally to the shape you want, steaming them perhaps?
I found that just soaking the planks for 20/30 mins makes them easier to bend with this model anyway, i know when i first built this 30 odd years ago you had to steam the planks which i think works well i recall reading somewhere that using a steam iron for bending the planks is one good way by steaming and bending the wood at the same time you can also buy plank benders but have never used one so cannot comment on how good they are and patience is a big asset when doing this job.
If you try to rush the planking you will end up breaking more than you bend lol.
hope this helps
steve
hope this helps
steve
