Revelle 1/72 corvette
    Look what came today
    [ATTACH]94019.IPB[/ATTACH]
    [ATTACH]94020.IPB[/ATTACH]
    [ATTACH]94021.IPB[/ATTACH]
    [ATTACH]94022.IPB[/ATTACH]
    [ATTACH]94023.IPB[/ATTACH]
    [ATTACH]94024.IPB[/ATTACH]
    [ATTACH]94025.IPB[/ATTACH]
    I put the warspite on her just to show how big she is. I am going to be a good boy though not starting it till I've finished my warspite dio. well Im going to try and be good, well almost certainly be good--ish,,,,, sort of.
  • monica
    • Oct 2013
    • 15169
    oh Lol, do you think you can be good i dont, :P
    looks nice and so meny meany little bits,
    cannot wait to see what you do with this one
      • 22950
      That looks a like a very nice kit Ken.
      In that scale I think it would be better with a full hull so anyone could turn it into an RC build
      • BarryW
        • Jul 2011
        • 6105
        That is the old Matchbox kit, I had it once when I went through a 'boat' stage way back in the late 70's early 80's. It really is a nice impressive kit but the detail needs some work, the main gun is rather crude for instance. I will keep an eye on this, I am sure you will do a much better job than I did way back then....
          I will watch this, with interest
            well made a start today
            [ATTACH]95336.IPB[/ATTACH]
            [ATTACH]95337.IPB[/ATTACH]
              Hi all well the hull halves are together.
              [ATTACH]95509.IPB[/ATTACH]
              [ATTACH]95510.IPB[/ATTACH]
              as you can see will need a fair amount of sealant to waterproof it, even though I used a vise the gaps are still quite large. just waiting for the brass rod and tube for the prop shaft to come then I will seal it all.
              [ATTACH]95511.IPB[/ATTACH]
              [ATTACH]95512.IPB[/ATTACH]
                • 22950
                Lots of daylight Ken it would make a good sub at the moment
                  Hi all here is the next stage.
                  [ATTACH]95755.IPB[/ATTACH]
                  [ATTACH]95756.IPB[/ATTACH]
                  [ATTACH]95757.IPB[/ATTACH]
                    Hi all got the radio gear in it now.
                    [ATTACH]95957.IPB[/ATTACH]
                    [ATTACH]95958.IPB[/ATTACH]
                    [ATTACH]95959.IPB[/ATTACH]
                      • 18301
                      I bet you will have this finished and in the water before I have finished mine and she's a static!
                        • 22950
                        Very nice work so far Ken
                          well did some filling and glued some deck parts on and added the wooden decking to the rear.[ATTACH]97288.IPB[/ATTACH]
                          [ATTACH]97289.IPB[/ATTACH]
                            I have just ordered the standard version of the same kit so i will be watching this build closely. The photo etch in this scale will be a dream to work with rather than the 1:350 scale that i am working with at the moment.
                            I am going to be plastic welding the hull together then using epoxy filler to eliminate any gaps and use the filler to hold the stuffing tube in place.
                            • james pithouse
                              • Dec 2014
                              • 1295
                              well ken it needs a deck before it hits the water or it will sink Ha! Ha! . But very nicely done. by the way on Ebay they got the clipper off the Cutty Sark at 1/75 scale for £329.99 the size that dad built in penge before I was born, well I'm hoping to get that one next to do when I can save some money up for it. which works out to be 3ft in length ruffly give or take a few inches.
