HMS Invincible 1/700 cyber hobby
    I've eventually pulled this kit out of the cupboard and started to give it a go this afternoon. The hull structure went together really well compared to some of the starter kits I'll been trying out over the last few months etc.(I'm a complete novice compared to you guys) bar a few minor issues fit wise.
    Started off by sanding the raised lines off on the flight deck 'as' advised somewhere I read online regards this build.Before I did this a few attempts of pencil rubbings were made -just to be on the safe side..(deck lines etc) . Long way to go, but I'll update when the build progresses .
    • 22851
    Nice start Steve.
      More filling,sanding and spraying and more sanding. I'm still not that happy with it so far. Looks like I went with the wrong Humbrol colour match for the deck going off a convertion chart online ...that and my novice mixing of acrylics and air spraying. I've a lot to learn!
        • 22851
        Not looking too bad at all Steve
          Looking great!
          I've learnt (read; I'm learning) to modulate paint when it didn't turn out exactly like I imagined it by spraying a really thin layer of clear colours from Tamiya, range X-23 to X-27, to change the hue of the colour.
          If a colour is too dark I can modify it somewhat by spraying a mist coat of XF-57 Buff or just a very thin coat of the base colour with added light/dark tones to change the shade.
          It can't rescue when the colour is totally wrong, but you can tweak an almost correct colour.
          I also practise doing the same with artist oil paint and a brush which is very handy if you're only doing a certain area, detail or panel.
          A clear coat can also change the tone slightly which can be both an advantage - and a disadvantage, if you're unaware of it.
          The final stage of weathering is what really changes the tone and appearance for me but I guess it's more noticeable on a banged up, dirty and muddy tank than a majestic ship...
          Experience in my world isn't knowing how to do it right from start - it's to know how to recover from a failure! I fail a lot so I guess I'm also learning loads... hehe...
            Originally posted by Jens Andrée
            Looking great!
            Thanks Jens for the reply and great advise, I'm still tying and failing but loving it! Frustrating at times ;-)
              Todays progress- Left the flight deck the colour it was and started on the lines etc. (more tape ordered ;-) ) Tried to tone the white down a bit and some 'touch up' required.
                Those lines look really good
                  Only had a few hours on the build this week. More work on the flight deck and started on the Hull( just taken the masking off) with a bit more work on the super structure also. Also had a go with the PE on one of the masts, not best of results as its my first attempt with this stuff! Going with G-S hypo cement at the moment as I didn't fancy a instant fix with CA (confindence thing!).
                    Small up-date regards this build- A couple of week back I stripped off the flight deck after not being happy with the colour etc. and started again.Did a bit of mixing of my own, which I'm kind of happy with-looks better than the first attempt I think ? More progress today adding decals etc. ..but the american 'style' R05 decal has miffed me off a-bit. Better photo's to follow when she progress's more.
