  • boatman
    • Nov 2018
    • 14498
    • christopher
    • NORFOLK UK
    #2836
    Lovely Chris, luv the carry frame !!
    Always amazed by your work and they float as well
    CHEERS Bob m8 an glad you like the carry frames as this idea the ship is easy to carry around without fear of breakin the model bit like carryin a suitcase an yes the ships float as well lol
    chris
    • Gavalaar1980
      • Aug 2020
      • 515
      #2837
      Superb craftsmanship Chris, excellent work indeed. How long has this project taken you so far?
      • boatman
        • Nov 2018
        • 14498
        • christopher
        • NORFOLK UK
        #2838
        HI Gavin well the ship HMS TIGER that im building now is just over about 2 an a half yrs an still about 2yrs or so to go to finish as i started her in early 2019 if you look at the start of the build you will see the date of the build start an many thanks for your kind comments on my work very nice of you an thanks for lookin in on the build still a lot more to come though
        ATB chris
        • boatman
          • Nov 2018
          • 14498
          • christopher
          • NORFOLK UK
          #2839
          HI GUYS well im back on tigers build
          but im now doin small stuff an thats them two bridges an i dont know how much will be seen when the light green glass is fitted in the windows
          but a freind has made me up some bridge consoles to fit in side of the bidges as i hate havin an empty bridge an im gonna try an make them fit inside the bridges with 2mm leds some just on an some flashing
          but first the console an its a solid resin but i have used my mini dremel an a borein out tool fitted to make them hollow
          first though the console below Click image for larger version
          • boatman
            • Nov 2018
            • 14498
            • christopher
            • NORFOLK UK
            #2840
            an here im now fittin in the 2mm leds an this is very fiddley work as ive had to cut off the resitor so the hair thin wires will go through the tiny holes an then try an resolder the wires back onto the resitor an you can see how small they are against my finger tip Click image for larger version
            • boatman
              • Nov 2018
              • 14498
              • christopher
              • NORFOLK UK
              #2841
              an three leds fitted in with their resitors fitted on an the resitores will all be tucked away out of sight in the hollow console Click image for larger version
                • 22954
                #2842
                Great work Chris.
                • boatman
                  • Nov 2018
                  • 14498
                  • christopher
                  • NORFOLK UK
                  #2843
                  one here done i havnt painted to much on the screen on the console as i dont think much will be seen but if it is seen better then i'll put on more detail but wont know untill ive fitted in the green bridge glass but the blue is just on an the orange an green are flashin ledsClick image for larger version
                  • boatman
                    • Nov 2018
                    • 14498
                    • christopher
                    • NORFOLK UK
                    #2844
                    Originally posted by papa 695
                    Great work Chris.
                    Cheers Ian an G/M to you
                    chris
                    • boatman
                      • Nov 2018
                      • 14498
                      • christopher
                      • NORFOLK UK
                      #2845
                      an two out of three done so far an these are just roughly painted as i said i dont think they will be seen much but if they are then i'll do a better job on them Click image for larger version
                      • boatman
                        • Nov 2018
                        • 14498
                        • christopher
                        • NORFOLK UK
                        #2846
                        AN HERE ive fitted in the white 2mm leds bridge lights an three in each bridge an these will be swiched on an off by R/C Click image for larger version
                        • boatman
                          • Nov 2018
                          • 14498
                          • christopher
                          • NORFOLK UK
                          #2847
                          HERE the bottom admrils bridge is all masked up ready for primer spray an top coat grey paint Click image for larger version
                          • boatman
                            • Nov 2018
                            • 14498
                            • christopher
                            • NORFOLK UK
                            #2848
                            an all now sprayed up an now for the really hard part of fitting in the green glazeing an i'll proberly be a nervous wreck by the time ive fitted it as ive got to be very carefull i dont get any glule smears on the glass an then fit window wipers Click image for larger version
                            • boatman
                              • Nov 2018
                              • 14498
                              • christopher
                              • NORFOLK UK
                              #2849
                              AN ive got too fill up that slight crack up just under the windows so back to marskin it up as this crack did no show before i painted it but it does now so more rework on this an then the other bridge to do
                              chris
                              • adt70hk
                                • Sep 2019
                                • 10540
                                #2850
                                Chris
                                Love the bridge consoles with the LEDs. A very nice little touch indeed. Very well done.
