  • boatman
    • Nov 2018
    • 14598
    • christopher
    • NORFOLK UK
    #3106
    Originally posted by outrunner
    All that wiring must be a bit tedious but I am sure the finished article will be a great sight to behold, well done you.
    Andy.
    AN HI Andy well i love wirein things up just for the challange of it to see if i can get it to work
    chris
    • boatman
      • Nov 2018
      • 14598
      • christopher
      • NORFOLK UK
      #3107
      AN well guys jen an i just done the wirein test an out of 44 wires only one dint work so i call that a 99% sucsses but ive now got to go to hospital for an eye op but when im better i will just part the hulls an put power through up to the hull jiont plug an usein the circut tester i will be able to find out where the trouble is wheather its front section or rear section but will have to leave it for now
      chris
      • Andy the Sheep
        • Apr 2019
        • 1864
        • Andrea
        • North Eastern Italy
        #3108
        My best wishes for your eye op: no surprise you've worn your eyes out on those wiring!
        • Airborne01
          • Mar 2021
          • 4368
          • Steve
          • Essex
          #3109
          Chris
          That is most rikky-tikky! Outstanding testament to your vision, skills and persistence. Superb!
          • boatman
            • Nov 2018
            • 14598
            • christopher
            • NORFOLK UK
            #3110
            Chris
            AN HI steve well i want to get this built an sailing so its a case of stick at it as there is still a lot more to go in her an loads of more soldering but thats what i enjoy so im happy just got to hope eye op goes ok or what ever they are gonna do
            ATB Chris
            • boatman
              • Nov 2018
              • 14598
              • christopher
              • NORFOLK UK
              #3111
              an thank you for your best wishes Andrea
              :thumb2:
              ATB
              Chris
                • 19134
                Excellent stuff Chris. That’s a lot to keep in your head though
                Hope the Op goes well and you’re back at it soon……
                • minitnkr
                  • 7809
                  • Dayton, OH USA
                  #3113
                  Good luck with the op Chris.
                  • outrunner
                    • Apr 2019
                    • 2420
                    #3114
                    I hope the op goes to plan Chris.
                    Andy.
                    • stillp
                      • 8313
                      • Pete
                      • Rugby
                      #3115
                      • Mini Me
                        • Jun 2018
                        • 10711
                        #3116
                        Hi Chris.........just make sure you leave the Hospital with both your "peeps" intact. :smiling3: :thumb2: Rick H.
                        • Neil Merryweather
                          • Dec 2018
                          • 5353
                          • London
                          #3117
                          All the best for the eye op, Chris
                          • boatman
                            • Nov 2018
                            • 14598
                            • christopher
                            • NORFOLK UK
                            #3118
                            THANK you all guys but they dint do the op as they said i may have to wait a yr or so but i had some eye tests an stinging eye drops put in an that was it
                            chris
                            • adt70hk
                              • Sep 2019
                              • 10553
                              #3119
                              chris
                              Actually being picky, it's 98% rounded to the nearest whole number.... But that's being very picky, especially when 98% would likely be my failure rate!! :tired:
                              In ALL seriousness Chris, very, very well done indeed, it must be a real weight of your mind.
                              ATB.
                              • boatman
                                • Nov 2018
                                • 14598
                                • christopher
                                • NORFOLK UK
                                #3120
                                ATB.
                                HI Andrew ok 98% but im pleased on that wireing just got to hope i done get any more fail as i found the wire that wont work as i removed the plug from the hull as i thought that if the wire is on the top or bottom row i can repair it but sods law has struck as its a wire right in the centre row of pins on the plug an if i try an open up the top an bottom wires knowin my luck i'll proberly do more damage an brake more wires as its thses rainbow ribbon wires as they only have about 4 strands of soft copper wire an they brake off easy so ive refitted the plug in the hull an jen an i did another load of wire testing again an they all now seem ok but if any more fail then i shall take them all out an replace the rainbow ribbon wire with them grey wires that i fitted in the front as they have been no trouble so see how we go on that
                                CHEERS for you post Andrew
                                chris
