  • boatman
    • Nov 2018
    • 14598
    • christopher
    • NORFOLK UK
    #346
    AN here in this pic im still getting it ready for glassin as I had to fit in plasticine dams to keep the liguid resin in place an even with all the maskin tape on the outside an plasticne dams the dam stuff still found a way to get out but thankfully I caught it before it went off hard an wiped it away Click image for larger version
    • boatman
      • Nov 2018
      • 14598
      • christopher
      • NORFOLK UK
      #347
      getting ready to pour more resin into the dams so hull has to be angled as flat as poss Click image for larger version
      • boatman
        • Nov 2018
        • 14598
        • christopher
        • NORFOLK UK
        #348
        an its succsessfullClick image for larger version
        • boatman
          • Nov 2018
          • 14598
          • christopher
          • NORFOLK UK
          #349
          more shots as im pleased how it all went starb sideClick image for larger version
          • boatman
            • Nov 2018
            • 14598
            • christopher
            • NORFOLK UK
            #350
            an port side an now they have all got to have any indentations filled an sanded down Click image for larger version
            • boatman
              • Nov 2018
              • 14598
              • christopher
              • NORFOLK UK
              #351
              • boatman
                • Nov 2018
                • 14598
                • christopher
                • NORFOLK UK
                #352
                Well for me that's the worst an most worrying thing over on the model as anything could have gone wrong but thanks to forward planning on how this was gonna happen it has all worked out ok in a day or so when the resin has really hardened then I will give the motors a run an to free up the grease in the prop tubes Click image for larger version
                • boatman
                  • Nov 2018
                  • 14598
                  • christopher
                  • NORFOLK UK
                  #353
                  the right way up shots an the prop tubes an sharfts are pretty good not pointing downwards by more than a few degrees which is jus dandy Click image for larger version
                  • Steven000
                    • Aug 2018
                    • 2947
                    • Steven
                    • Belgium
                    #354
                    Looks like a huge work to me Christopher :astonished:
                    Glad to see you got the job done :thumb2:
                    Cheers, Steven
                    • boatman
                      • Nov 2018
                      • 14598
                      • christopher
                      • NORFOLK UK
                      #355
                      • boatman
                        • Nov 2018
                        • 14598
                        • christopher
                        • NORFOLK UK
                        #356
                        Cheers, Steven
                        HI Steven yes I nearly gave up as it was very difficult to get all the props tubes in their correct postion but I thought its not gonna beat me cheers for your comment an intrest
                        chris
                        • boatman
                          • Nov 2018
                          • 14598
                          • christopher
                          • NORFOLK UK
                          #357
                          An a couple of shots inside the hull at the motors layout after fillin an sandin down outer hull prop tubes then it will be the next stage of electric's an then the fun stuff really begins then what I enjoy the most :thumb2: :thumb2: :thumb2: :thumb2: Click image for larger version
ID:	1108655Click image for larger version
                          • boatman
                            • Nov 2018
                            • 14598
                            • christopher
                            • NORFOLK UK
                            #358
                            sorry doubled up on that picClick image for larger version
                              Just remarkable the amount of detail and work you've put into this build.
                              Pete.
                              • boatman
                                • Nov 2018
                                • 14598
                                • christopher
                                • NORFOLK UK
                                #360
                                Pete.
                                HI Pete yes cheers for your nice comment an there's a heck of a lot more work to be done but im enjoyin it an its passin these ole winter days an we hope you feel better
                                all best chris
