  • scottie3158
    • 14638
    • Holbeach
    #1036
    Chris,
    Think I will stick to PE its a lot easier lol.
    • boatman
      • Nov 2018
      • 14595
      • christopher
      • NORFOLK UK
      #1037
      so that's the radar took care of till I build it in an now back too that other H-DOOR
      an ive got it workin but the servo must face the same way as the first one so to do this I have moved the H-DOOR mounting to the other side of the h-door an also the servo to the nr the center of the h-bay but then I thought I need a roof bar goin across the h-length to fix the pushrod too an when I open the h-door I don't want it to be seen an the cable ties will be cut off if it all works ok an ive fitted in a false back so that all the wiring wont be seen Click image for larger version
      • boatman
        • Nov 2018
        • 14595
        • christopher
        • NORFOLK UK
        #1038
        Gets better Chris, really admire this build:thumb2:
        cheers Bob
        • boatman
          • Nov 2018
          • 14595
          • christopher
          • NORFOLK UK
          #1039
          an in this picture can be seen the pushrod bent as much as I dare to go down to the h-floor an to the servo Click image for larger version
          • boatman
            • Nov 2018
            • 14595
            • christopher
            • NORFOLK UK
            #1040
            an the door works great I really did make myself more work when I went an stripped that servo down just to have to put it all back togeather again Click image for larger version
            • boatman
              • Nov 2018
              • 14595
              • christopher
              • NORFOLK UK
              #1041
              an I can get 3 choppers in but a bit to crowed so I think it will be two in the h-bay an two out on the fightdeck one goin an one standin the in the all fowled up postion Click image for larger version
              • boatman
                • Nov 2018
                • 14595
                • christopher
                • NORFOLK UK
                #1042
                an a pic of both servos fitted on the underside just waiting to go an ive ordered a Y LEAD to work both servos an hopefully form the servo morph so they will open an close slowley Click image for larger version
                • boatman
                  • Nov 2018
                  • 14595
                  • christopher
                  • NORFOLK UK
                  #1043
                  an now back to covering in that radar motorgearbox that's a tad noisey an ive glued in postion polysteren to hopefully cut down the noise from the motor an ive tomorrow got to build a box again covered in the polysteren over the motor itself Click image for larger version
                  • boatman
                    • Nov 2018
                    • 14595
                    • christopher
                    • NORFOLK UK
                    #1044
                    an that's the lot for tonight now time for tiffin as sid james said in carry on up the kyber lolClick image for larger version
                    • boatman
                      • Nov 2018
                      • 14595
                      • christopher
                      • NORFOLK UK
                      #1045
                      Chris,
                      HELLO SCOTTIE yea PE IS A LOT EASIER but I like a challenge
                      chris
                      • ojays
                        • Oct 2011
                        • 1713
                        #1046
                        an ive got it workin but the servo must face the same way as the first one so to do this I have moved the H-DOOR mounting to the other side of the h-door an also the servo to the nr the center of the h-bay but then I thought I need a roof bar goin across the h-length to fix the pushrod too an when I open the h-door I don't want it to be seen an the cable ties will be cut off if it all works ok an ive fitted in a false back so that all the wiring wont be seen [ATTACH=CONFIG]n1125638[/ATTACH]
                        an a pic of both servos fitted on the underside just waiting to go an ive ordered a Y LEAD to work both servos an hopefully form the servo morph so they will open an close slowley [ATTACH=CONFIG]n1125648[/ATTACH]
                        Some times the easy solution is difficult to see at first.
                        • boatman
                          • Nov 2018
                          • 14595
                          • christopher
                          • NORFOLK UK
                          #1047
                          HI Gregg yes you are right there but what kept buggin me was now I want the snake fitted to the hanger wall so its nice an neat an wont hardly be seen when all the hanger insides are painted white.
                          But after a bit of thought I thought well i'll postion the servo the same way as the first one an move the servo horn attachment on the H- door to the other side so the snake can run down the centre of the H-bay but what am I gonna fix it to to stop it bendin so a wooden beam fitted in to support the snake an it will also support the H-roof deck so killed two birds with one stone there an the door works ok but later there will be a bit of finer
                          adjustments to the doors as nearly every thing ive built so far that works will be finer tuned to say its finished with
                          anyway Gregg many thanks for your thoughts on this door workin subject an your nice little drawins an keep them comin if you please as what you think up I may not have even considerd at the time cheers
                          ATB STAY SAFE chris
                          • mrtintheweb
                            • May 2020
                            • 292
                            #1048
                            Interesting build indeed. My uncle was involved in the refit of her sister ship HMS Blake and it caught fire whilst being converted to carry helicopters.
                            I will see if he still has all the photos he took of the ship.
                            T
                            • boatman
                              • Nov 2018
                              • 14595
                              • christopher
                              • NORFOLK UK
                              #1049
                              T
                              OH GREAT Toby id be very pleased to see them as she is a sister ship to tiger as they might help me on tiger as they were an practiacly the same many thanks if you can
                              chris
                              • boatman
                                • Nov 2018
                                • 14595
                                • christopher
                                • NORFOLK UK
                                #1050
                                HI ALL another small update
                                well im been bugged by the noisey radar motor fittin it on rubber mountins an such an some of the guys said fittin polystyrene around the motor may make it quieter an yes its helped a bit so that's what ive been doin an ive also had to fit in a hatch so that if trouble with the R-MOTOR I can open it to get to the scrub screw that holds the main R - shaft an release it so the motor can be removed Click image for larger version
