BOATMAN's USS NIMITZ CVN 68 BUILD IN 1/144 SCALE
  • boatman
    • Nov 2018
    • 14598
    • christopher
    • NORFOLK UK
    #16
    An now she looks like a flat top Click image for larger version
    • boatman
      • Nov 2018
      • 14598
      • christopher
      • NORFOLK UK
      #17
      • boatman
        • Nov 2018
        • 14598
        • christopher
        • NORFOLK UK
        #18
        An after a heck of a lot of sandin an painting the hull with 6 coates of sandin sealer I sprayed her with about 10 coates of first red pimer an then gray an then finished with grey to make her water tight an firbre glassin her in side an out I then fitted all 4 prop shaft's an 4 rudders the real ship don't have 4 just 2 but I needed to make her do tight turns as I still found that on the crowded boat pond when she was sailin she still went over the top of smaller craft as this ship couldn't be stopped on a sixpence due to her wheight Click image for larger version
Name:	carrier build12.jpg
        • boatman
          • Nov 2018
          • 14598
          • christopher
          • NORFOLK UK
          #19
          NOW here after about a yr an a half of costrucion my m8 an I took her to the pond with about 50 pounds of batts wheight in the hull to see how she sits in the water test an she passed with flyin colours ( did a little dance again to celebrate :smiling4::smiling4::smiling4::smiling4: people were lookin at me very strangely :tears-of-joy::tears-of-joy:lol ) Click image for larger version
Name:	carrier build13.jpg
            Good to see you’ve got the pictures sorted That is one impressive model. I’ve seen plenty of large ship models built from wood, and this looks better than many already.
            • boatman
              • Nov 2018
              • 14598
              • christopher
              • NORFOLK UK
              #21
              Originally posted by Jakko
              Good to see you’ve got the pictures sorted :smiling3: That is one impressive model. I’ve seen plenty of large ship models built from wood, and this looks better than many already.
              Hi Jakko many thanks for your kind comments an tryin to help me with the pics as it did get a bit tedious swoppin them one at a time from bitmap to jpeg but got there in the end I will fit more pics of the build tomorrow
              • boatman
                • Nov 2018
                • 14598
                • christopher
                • NORFOLK UK
                #22
                HI all some more pics of the build
                here I have made an fitted the aircraft evevator shuttle rails as this model had working aircraft elevators 3 working an one dummy over the batt bayClick image for larger version
Name:	carrier build14.jpg
                • boatman
                  • Nov 2018
                  • 14598
                  • christopher
                  • NORFOLK UK
                  #23
                  A shot of the front half Click image for larger version
Name:	carrier build15.jpg
                  • boatman
                    • Nov 2018
                    • 14598
                    • christopher
                    • NORFOLK UK
                    #24
                    an the stern end with the bilge keels fitted an if looked at closely you can see the tubes comin through the hull for the push rods to work the aircraft elevator up an down Click image for larger version
Name:	carrier build16.jpg
                    • boatman
                      • Nov 2018
                      • 14598
                      • christopher
                      • NORFOLK UK
                      #25
                      A shot of the aircraft elevator lift bar fitted with the push rods Click image for larger version
Name:	carrier build18.jpg
                      • boatman
                        • Nov 2018
                        • 14598
                        • christopher
                        • NORFOLK UK
                        #26
                        AN the megtronics aircraft elevator unit I call it as it half mechanical an half eletronic's this unit is what pushes the aircraft elevators up an down an there are 3 of these in the shipClick image for larger version
Name:	carrier build19.jpg
                        • boatman
                          • Nov 2018
                          • 14598
                          • christopher
                          • NORFOLK UK
                          #27
                          NXT the lift bar fitted into the shuttle railsClick image for larger version
Name:	carrier build17.jpg
                          • boatman
                            • Nov 2018
                            • 14598
                            • christopher
                            • NORFOLK UK
                            #28
                            two shots of the exess hatches cut outs an these will be held in place by small screws an tiny magnets where I will open them alotClick image for larger version
Name:	carrier build20.jpg
                            • boatman
                              • Nov 2018
                              • 14598
                              • christopher
                              • NORFOLK UK
                              #29
Name:	carrier build21.jpg
                              • boatman
                                • Nov 2018
                                • 14598
                                • christopher
                                • NORFOLK UK
                                #30
                                here is her motive power 4 grupner 12v 600 motor's with cam belt drive reduction gear ratio 3 to 1 step down with aircraft elevator megtronics fitted for lifts no. 3an 4
                                at the rear of the carrier Click image for larger version
Name:	carrier build22.jpg
