BOATMANS HMS NORFOLK BUILD in 1/72 SCALE
  • boatman
    • Nov 2018
    • 14498
    • christopher
    • NORFOLK UK
    #46
    • boatman
      • Nov 2018
      • 14498
      • christopher
      • NORFOLK UK
      #47
      markin out the bridge windowsClick image for larger version
      • boatman
        • Nov 2018
        • 14498
        • christopher
        • NORFOLK UK
        #48
        AN CUTOUT later in the build the bridge will have lights fittedClick image for larger version
        • boatman
          • Nov 2018
          • 14498
          • christopher
          • NORFOLK UK
          #49
          Now a shot of the underside of the main S/S an I have fitted in the radar motor this will work three radars at once
          an the steel rod that goes over at an angle is the drive shaft from the radar motor to work a radar mounted on the bridge roof again this all unscrews for servercingClick image for larger version
          • boatman
            • Nov 2018
            • 14498
            • christopher
            • NORFOLK UK
            #50
            Now to a diffent part of the S/S this a plastic grill fitted on the top as this is where the mylar waterproof speaker is fitted for the sound systems in this case a battle whoopin siren an a fog horn sound both units operate through the same speakerClick image for larger version
            • boatman
              • Nov 2018
              • 14498
              • christopher
              • NORFOLK UK
              #51
              NXT building the foremast again this all unscrews to be taken off in case of a problemClick image for larger version
              • boatman
                • Nov 2018
                • 14498
                • christopher
                • NORFOLK UK
                #52
                Now this small radar is a surface search radar I think as the big radar on top of the mast is the air search with IFF INTERGATOR to be seen in pics to come
                anyway back to this one an it all works with mini crown gears an sharfts an again it can be unsrewed an taken off the mast Click image for larger version
                • boatman
                  • Nov 2018
                  • 14498
                  • christopher
                  • NORFOLK UK
                  #53
                  An built in an filled with a load of grease to prevent wear on the gearsClick image for larger version
                  • boatman
                    • Nov 2018
                    • 14498
                    • christopher
                    • NORFOLK UK
                    #54
                    its all screwed down in case I want to get into it for servicin an it filled with balsa wood to keep top wheight down Click image for larger version
                    • boatman
                      • Nov 2018
                      • 14498
                      • christopher
                      • NORFOLK UK
                      #55
                      NOW mounted on the fore mast all ready to revolvleClick image for larger version
                      • boatman
                        • Nov 2018
                        • 14498
                        • christopher
                        • NORFOLK UK
                        #56
                        NXT building the seawolf missle siloClick image for larger version
                        • boatman
                          • Nov 2018
                          • 14498
                          • christopher
                          • NORFOLK UK
                          #57
                          these missle are for anti air defence an short rangeClick image for larger version
                          • boatman
                            • Nov 2018
                            • 14498
                            • christopher
                            • NORFOLK UK
                            #58
                            An silo builtClick image for larger version
                            • boatman
                              • Nov 2018
                              • 14498
                              • christopher
                              • NORFOLK UK
                              #59
                              THAT IT FOR NOW
                                • 18301
                                Cracking good that.
