Amati 1\250 RMS Titanic full kit
  • peterairfix
    • Jul 2012
    • 11139
    This is going to be my last Titanic build its the one I have promised myself it's the same size as my last build but completely different in build quality.Click image for larger version
  • minitnkr
    • 7785
    • Dayton, OH USA
    Looks impressive. PaulE
      • 16158
      Hi Peter
      That is quite a model. I assume it is a wooden kit. A lot of work but will be impressive when built.
      • peterairfix
        • Jul 2012
        • 11139
        Yes it's almost the same as the part work one but with a lot difference between build and parts.
        • boatman
          • Nov 2018
          • 14498
          • christopher
          • NORFOLK UK
          WELL how big is it length an beam ?
          chris
          • peterairfix
            • Jul 2012
            • 11139
            chris
            Length will be 107cm beam is not given so I will have to measure my older kit to find out.
            • peterairfix
              • Jul 2012
              • 11139
              I just have opened the box and there are buckets of parts wood eight sets of plans one colour book and a full size 1-1 plan.
              The first thing to do is I definitely the first five bulkhead's and the bow keel section it shouldn't be hard as there are only two keel sections as apposed to six on the part work one and the next thing done is to angle the first five bulkhead's.Click image for larger version
ID:	1106408Click image for larger version
ID:	1106409Click image for larger version
ID:	1106410Click image for larger version
ID:	1106411Click image for larger version
ID:	1106412Click image for larger version
ID:	1106413Click image for larger version
ID:	1106414Click image for larger version
ID:	1106415Click image for larger version
ID:	1106416Click image for larger version
ID:	1106417Click image for larger version
              • peterairfix
                • Jul 2012
                • 11139
                Building has commenced this is the easiest part of the build witch consists of the two keel sections and the 22 bulkheads witch form the basic structure and the two well decks and two strengthening running parallel to the keelClick image for larger version
ID:	1106486Click image for larger version
ID:	1106487Click image for larger version
ID:	1106488Click image for larger version
                • peterairfix
                  • Jul 2012
                  • 11139
                  Just finished off the first part of planking on the bow and stern well decksClick image for larger version
ID:	1106557Click image for larger version
                  • peterairfix
                    • Jul 2012
                    • 11139
                    Just finished off planking the next four deck pieces ready for the next construction phase.Click image for larger version
                    • peterairfix
                      • Jul 2012
                      • 11139
                      A few more parts added today they are the spare anchor well the first of the wall on the forward well deck and the last of the parts on the fan tail that support the stern deck.Click image for larger version
ID:	1106767Click image for larger version
ID:	1106768Click image for larger version
                      • scottie3158
                        • 14565
                        • Holbeach
                        Peter,
                        Nice work mate, you certainly like your Titanic's
                        • peterairfix
                          • Jul 2012
                          • 11139
                          The first two decks have been attached along with the first two pieces of planking.Click image for larger version
ID:	1106817Click image for larger version
ID:	1106818Click image for larger version
                            I soooooo wanted this kit (with the rc pack) I could just never convince the missus. You lucky son of a gun.
                            I will be glued to this build.
                            • peterairfix
                              • Jul 2012
                              • 11139
                              Time for an update I have added two more decks at the stern plus the formers for the walls I haven't put any decoration on as I am waiting for my PE walls and also I have shaped the stern fantail to the correct shape and attached the sternpost.Click image for larger version
ID:	1107297Click image for larger version
ID:	1107298Click image for larger version
ID:	1107299Click image for larger version
ID:	1107300Click image for larger version
