Another Hachette Build the Titanic
  • peterairfix
    • Jul 2012
    • 11139
    #16
    Planking all finished all ready for sanding and the next stage of the build Click image for larger version
ID:	1159050Click image for larger version
ID:	1159051Click image for larger version
ID:	1159052Click image for larger version
ID:	1159053Click image for larger version
ID:	1159054Click image for larger version
ID:	1159055Click image for larger version
      • 16162
      Hi Peter
      Great progress and looking good. Now sanding which must be time consumming and boring.
      • peterairfix
        • Jul 2012
        • 11139
        #18
        If I have my planking done right it should quickly done as I have another layer to add which contains the portholes.
        • peterairfix
          • Jul 2012
          • 11139
          #19
          I have started the next stage which involves adding a second layer of planking that contains the portholes I have only shown one part as its all the same for both sides. Click image for larger version
ID:	1159131Click image for larger version
          • boatman
            • Nov 2018
            • 14498
            • christopher
            • NORFOLK UK
            #20
            great work Peter chris
            • peterairfix
              • Jul 2012
              • 11139
              #21
              I have finished the second layer of planking and started to drill out the portholes and to save time on changing bits I have a double ended drill and one single. Click image for larger version
ID:	1159274Click image for larger version
              • boatman
                • Nov 2018
                • 14498
                • christopher
                • NORFOLK UK
                #22
                Comin on well Peter this should look really realistic
                chris
                • adt70hk
                  • Sep 2019
                  • 10540
                  #23
                  Coming on nicely Peter. Keep up the good work.
                  • peterairfix
                    • Jul 2012
                    • 11139
                    #24
                    Second layer of planking finished and portholes drilled out Click image for larger version
ID:	1159334Click image for larger version
                    Now this is where I go against the instructions as it says to add pieces of wood see pictures Click image for larger version
ID:	1159336Click image for larger version
                    Now I have found out that doing the recommended way that the next piece of ship sits proud of where it should be Click image for larger version
                    By removing all the pieces it now sits flush Click image for larger version
                    • peterairfix
                      • Jul 2012
                      • 11139
                      #25
                      The Hull is about finished and I am now putting in all the portholes. Click image for larger version
ID:	1159428Click image for larger version
ID:	1159429Click image for larger version
                      • peterairfix
                        • Jul 2012
                        • 11139
                        #26
                        I now have a set of photo etched parts as it gives me the side profiles for b deck and the bow and stern.
                        Because the problem with the original build that the portholes are drilled it and it comes in three pieces. Click image for larger version
                        And the photo etched only has one join and has riveting details and looks a whole lot better. Click image for larger version
ID:	1160083Click image for larger version
ID:	1160084Click image for larger version
                        • adt70hk
                          • Sep 2019
                          • 10540
                          #27
                          Peter
                          That does look so much better, not to mention a whole lot quicker than doing each one individually.
                          Keep up the great work.
                          • peterairfix
                            • Jul 2012
                            • 11139
                            #28
                            I have got to the point where I can put the undercoat on. Click image for larger version
ID:	1160135Click image for larger version
                            • peterairfix
                              • Jul 2012
                              • 11139
                              #29
                              Got the rest of the paint on and started on the promonade deck walls. Click image for larger version
ID:	1160189Click image for larger version
ID:	1160190Click image for larger version
ID:	1160191Click image for larger version
ID:	1160192Click image for larger version
                              • boatman
                                • Nov 2018
                                • 14498
                                • christopher
                                • NORFOLK UK
                                #30
                                REALLY super modeling Peter this is really comin on could it actually float as it looks as though the hull in water proff ?
                                chris
