USS Constipation 1/120 scale Imai long suffering build
    • 22954
    #106
    Nice fixes Richard.
    • rtfoe
      • 9208
      • Richard
      • Shah Alam, Malaysia
      #107
      Originally posted by Jim R
      Hi Richard
      You're definitely making progress. Good luck painting that front bit - a nice steady hand.
      Thanks Jim, hands not as steady but use my fingers to steer the brush. I will be doing a few passes and touch up with a black wash.
      Originally posted by wotan
      I am enjoying this build and the skill that you are demonstrating. Nice save on the stern davit. Just a question, your mizzen mast looks like it is made up of one long pole whereas it normally consisted of at least two and probably three separate masts joined at each of the cross trees. Am I just missing something?
      Thanks John, it's made up as you mentioned by a few poles. The section that was missing lucky for me the instruction sheet had photos so it was just a continuation from that crisscross thingy to the top which held the final crosstree and sail. There are two forward sails above the main mizzen mast sail. Very tall ship this.
      Originally posted by papa 695
      Nice fixes Richard.
      Thanks Ian.
      • rtfoe
        • 9208
        • Richard
        #108
        Here John is a pics of the mizzen mast.
        The white section just before the top is what I replaced. Should have a slight taper but I left it as that. Will paint it brown to match the little sliver at the top after scratching the crosstree bracing.
        • rtfoe
          • 9208
          • Richard
          #109
          While waiting for my HP to charge up before going to bed I painted the large gun cradles of the main gun deck. Although they slot into their individual compartments there is a bit of the cradle seen. The cradles on the main deck aren't the same color as on the top deck and are lighter brown.
          Doing this is like assembling tank tracks...I don't envy the guys doing HMS Victory. :smiling6:
          • rtfoe
            • 9208
            • Richard
            #110
            Did highlights to the cannon with Testors brass enamel dry brushing it on...
            Then I'll brush in a coat of gloss varnish as these fellas were shiny with the continuous gun crew attention.
              • 16165
              Hi Richard
              That's already a nice finish on those cannon.
              • scottie3158
                • 14578
                • Holbeach
                #112
                Richard,
                All coming together very nicely mate.
                • rtfoe
                  • 9208
                  • Richard
                  #113
                  Hi Richard
                  Thanks Jim, I went a little further by adding gunmetal blue after finding a bottle of Vallejo.
                  The ones on the left are blued...
                  The one on the gun deck is more apparent. I don't know if blueing the guns were a technique already used at that time.
                  • rtfoe
                    • 9208
                    • Richard
                    #114
                    Richard,
                    Thanks Paul, very slowly but surely.
                    • wotan
                      • May 2018
                      • 1187
                      #115
                      Very nice looking guns Richard. Are you going to fully rig those that are visible?
                      • rtfoe
                        • 9208
                        • Richard
                        #116
                        Thanks John, I will definitely try. I have some references and for each gun there is quite an amount of attachments with rope for recoil and another to pull and reposition the gun. Probably wing it. Some of the carronades trolleys are bolted to swivel mounts to the gunwhale and don't have as much ropes.
                        • wotan
                          • May 2018
                          • 1187
                          #117
                          I just added the ropes to run out the guns on most of my models. They are fiddly to attach but look convincing when done.
                          • rtfoe
                            • 9208
                            • Richard
                            #118
                            Any pictures that can help for reference John? I like stuff that is just enough to be convincing.
                            Richard.
                            • wotan
                              • May 2018
                              • 1187
                              #119
                              These are of a very dusty HMS Unicorn I built some years ago. You can see how the rigging runs through two blocks, is fastened to the hull and the loose end is coiled down on the deck.
                              Hope that helps.
                              • rtfoe
                                • 9208
                                • Richard
                                #120
                                [ATTACH=CONFIG]n1169920[/ATTACH]
                                [ATTACH=CONFIG]n1169921[/ATTACH]
                                [ATTACH=CONFIG]n1169922[/ATTACH]
                                Hope that helps.
                                Thats a mighty fine looking ship John and the reference is helpful, thank you. The kit provides blocks but are large for the ships rigging so I might need to scratch one and cast others from there.
                                Guns have just been fitted below...
