1/72 HMS Iron Duke - Type 23 Frigate
  • Tworrs
    • Jan 2022
    • 1982
    • Garry
    • New Zealand
    #121
    Originally posted by boatman
    HI Garry any chance of you sending us a pic of that lake where you will saill I/D
    ? an have you got your R/C set yet ? as love to see a pic of it when you can
    Chrisb
    Sorry, I don't have a pic of the lake, however I'll try to get one next time I'm there.
    Delivery for my TX is scheduled for 28th, so waiting patiently.
    Garry
    • boatman
      • Nov 2018
      • 14600
      • christopher
      • NORFOLK UK
      #122
      HI again Garry on your new T/X has it a knob that u can turn fitted on as that is a great help an fitting that channel to a servo with a cam an knock on switches that way u can get another up to 5 workin functins if you want them
      chrisb
      • Tworrs
        • Jan 2022
        • 1982
        • Garry
        • New Zealand
        #123
        I found a media pic of the lake from the racing this weekend.
        • Tworrs
          • Jan 2022
          • 1982
          • Garry
          • New Zealand
          #124
          chrisb
          Chris the TX has 2 rotary knobs on it so I would imagine they would be able to do what you are thinking
          I'll see once I get it.
          • boatman
            • Nov 2018
            • 14600
            • christopher
            • NORFOLK UK
            #125
            OH GREAT Garry as that what my carsons 14 cha has two rotary knobs an very handy they are on mine ive used both knobs so i have 10 other functions to work thing an its great pic of it belowClick image for larger version
            • Tworrs
              • Jan 2022
              • 1982
              • Garry
              • New Zealand
              #126
              This is the TX that I have on the way.
              • boatman
                • Nov 2018
                • 14600
                • christopher
                • NORFOLK UK
                #127
                [ATTACH=CONFIG]n1186547[/ATTACH]
                HI Garry looks great but i see its for aircraft isnt it but it should do all that you want it to do on your ship an 10 channels incluedin the two rotary knobs oh you can have several functions goin as you have done right by buyin a 10 channel T/X
                as ive seen people up the boating lake turn up with nice lookin ships but then say cor wish i had more channels on my T/X as they have just bought a 4 channell T/X which will just give the basic workins an no more so they then have to fork out more dosh on a bigger an more channels T/X so well done on that you have saved yourself quite a bit of dosh an my T/X can hold up to i think 10 models in its memory do you know what yours will do ? but i'll do as you say wait till it comes but i should think it will or maybe more but keep your updates comin im really enjoyin seein this
                chrisb
                • Tworrs
                  • Jan 2022
                  • 1982
                  • Garry
                  • New Zealand
                  #128
                  Chris, it is actually designed for a quadcopter, but a TX is a TX in my mind, it will do what I tell it to do lol, as I mentioned before it will do 20 models in memory.
                  I have made a start on the electronics now, so it is becoming quite interesting.
                  A couple of green LED's in the bridge
                  2 White LED's in the stern
                  Battery with fuse
                  2 Power converters (so far) and some distribution blocks.
                  Garry
                  • boatman
                    • Nov 2018
                    • 14600
                    • christopher
                    • NORFOLK UK
                    #129
                    WOW Garry you certainly are steamin full ahead VERY WELL DONE my good freind but im not critizin but this is just an observation on your stern but are you not goin to cut the hole for the elephants ass as its called as i see you have wires goin right where that should be ? but you are an incredible modeller an them blue things are they power converters ? an im really enjoyin seein your work at this rate it will be built in a yr or so WOW an thank you for loads of lovely pics really make my day to see some new ideas press on an have you thought about your ESC yet as it will need to be able to take about 30 amps as these models when you get water load on the props the eletric current rateing goes up so you will need about a 25 amp fuse in to protect your ESC against dead stall eg. weed around the props as ive had this happen on my norfolk an my 30 amp fuse blew so it protecked MY ESC AN MOTORS BUT BRILLIANT BUILD
                    ATB to you Garry
                    chrisb
                    • Tworrs
                      • Jan 2022
                      • 1982
                      • Garry
                      • New Zealand
                      #130
                      ATB to you Garry
                      chrisb
                      I know about the ESC mate, I mentioned to you previously that I have a 30amp unit in stock.
                      No, I won't be adding an elephants ass to the stern of HMS Iron Duke F234, as according to my reference pics she doesn't have one.
                      • boatman
                        • Nov 2018
                        • 14600
                        • christopher
                        • NORFOLK UK
                        #131
                        WELL that a rummom Garry as in this pic below she has its for the trailing sonar unit to detect sub an this is I/D all can think then they must have cut off Click image for larger version
                        • Tworrs
                          • Jan 2022
                          • 1982
                          • Garry
                          • New Zealand
                          #132
                          This was a rather fiddly job, the front gun turret, 24 pieces so far and not finished yet.
                          Not great, but it will get better with filling and sanding, and it was a lot quicker than waiting months for one to get here from the UK.
                          • Mini Me
                            • Jun 2018
                            • 10711
                            #133
                            That'll work.....I once had a similar experience while trying to scratch build a WWll German armored car. Crazy angles in all directions!
                            • boatman
                              • Nov 2018
                              • 14600
                              • christopher
                              • NORFOLK UK
                              #134
                              WOW Garry very well done on that crylin gun turret as i bought mine from fleetscale to save all that work honestly you certainly are a great moddeler an you put me in the shade with this gun turret all them angles as it to do with the stealth but as you say once its got the cracks filled an sanded down it will look the bees knees as i have never attempted this not when i could get one for a few pounds VERY WELL DONE INDEED SIR i think your I/D will look a cracker when you built her but weird about that elephants ass is'nt it as ive never seen a type 23 without one wonder what they got instead now ?
                              KEEP THE UPDATES COMIN Garry im really enjoyin this to see how you go about thing different to how i would
                              ATB
                              chrisb ps how long did it take to get to this stage on that gun turret ? an im very impressed indeed
                              • Tworrs
                                • Jan 2022
                                • 1982
                                • Garry
                                • New Zealand
                                #135
                                Yeah Rick those angle do your head in don't they?
                                ATB
                                Thanks Chris, I would have preferred to just get one from Fleetscale, but they are so far behind with their orders now, my first order still hasn't been posted after about 6-7 weeks and the second either.
                                It does build up my skills though, and teaches me patience too. The turret has taken a few days so far.
                                ATB Garry
