Billings HMS Victory
    Originally posted by \
    Hi Paul, nice work on the planking, its all loking very nice and accurate. I was wondering if you could upload a few photos of the kit contents/parts. I am looking to buy the billings victory after my current ship is complete! Thanks very much,Pete
    Here are a couple of the remaining contents of the kit Pete..... Still a fair bit left
    [ATTACH]66319.vB[/ATTACH] [ATTACH]66317.vB[/ATTACH][ATTACH]66318.vB[/ATTACH]
    [ATTACH]67400.IPB[/ATTACH]
    [ATTACH]67401.IPB[/ATTACH]
    [ATTACH]67402.IPB[/ATTACH]
      looks like a timber yard lol,good progress so far
      mobear
        Coming along great. keep up the good work.
        Andy
          Hi folks.... Still ongoing with the Planking, most of the lower hull is done and the planks are now past the Wales.
          I might be completely wrong here but on the upper section of the hull to the bottom of the Wales do you plank from the Deck down to the completed lower hull planking? Or just carry om planking from the keel up to the Decks?
          I know that sounds like rubbish lol
          Just found this link on how to Plank Boats... pretty comprehensive to say the least. Downloads as a PDF.
          http://www.google.co.uk/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0CC8Q FjAA&url=http%3A%2F%2Fmodelshipworldforum.com%2Fre sources%2FFraming_and_Planking%2Fplankingprojectbe ginners.pdf&ei=MTr9UYrDFMXa0QWFxYH4CQ&usg=AFQjCNG_ bjD-yBKre4UG7l32q07GjeOl-w&bvm=bv.50165853,d.d2k
          Paul
            Paul,
            very interested to see how you are tackling the planking, I am just about to start this, but am having difficulty in working out how the stern goes, there doesn't seem to be any drawing, photos of the stern area to give a clue, how did you approach it?
            Rusty
              Paul,very interested to see how you are tackling the planking, I am just about to start this, but am having difficulty in working out how the stern goes, there doesn't seem to be any drawing, photos of the stern area to give a clue, how did you approach it?
              Rusty
              Hi Rusty.... I started from the Keel upwards. I have soaked the Planks in the bath overnight and have found this to be helpful in bending them. On the Stern I have let them take a natural course and trimmed off the excess off when dry. When starting from the keel they have bowing out and when it came to bending them around the frame steaming them and pinning in place. I decided to plank horizontally along the Whales and join just below.
              Here is a picture of the progress and a reference shot I found on the Internet.
              When all the planking is in place I am going to Plane the extreme edges off, small amounts of Filler and them sand smooth. That's after cutting out all those Gunports....
              Paul
              [ATTACH]68118.IPB[/ATTACH]
              [ATTACH]68119.IPB[/ATTACH]
                hi paul here is a little cheat when planking, if you have little gaps to filll in, lie your shlp on its side. get your spare bits of wood, put pva glue in gap, use sandpaper to put sawdust in gap. leave to dry overnight . sand off with fine sandpaper leaving a nice filled gap good luck regards rob
                  Paul,
                  thanks for the info, I am finding this build quite a challenge and your photos have helped a lot
                  Rusty
                    Thanks for that, just tried that it works really well!
                      Paul,thanks for the info, I am finding this build quite a challenge and your photos have helped a lot
                      Rusty
                      No problems I am glad they helped. I am no expert at this so hoping I get it right
                      I have been cutting out the Gunports and putting more of the planking up the hull. Just had to stop until the glue dry's.
                      Paul
                      [ATTACH]68339.IPB[/ATTACH]
                        hi paul, here is another tip a little further into your project. when you come to your rigging i.e tying knots from location to location . when you have them where you need them held in place permantely held, dont use superglue. use cheap clear nail varnish with cocktail stick. blow on it to set holding tension on tweezers
                          hi paul i have done a few pof models. also was a plater/ shipwright in shipyards many moons ago very happy to help. here is another tip if you do another ship kit. try and research your project on line or in library be surprised how you can beef up your detail it to a superb model regards rob
                            Thanks I will try that.... seems ages away yet but will get there in the end.
                            What yard were you in? Tyne or Wear?
                              i worked in both yards on the tees . swan hunters and smiths dock to finish my time swans was my favourite holiday camp. Oh well happy days! Let me know if you need anymore help. also remmember keep workin g both sides at same time keeps the job right regards rob
                              • Adrian "Marvel" Reynolds
                                • Apr 2012
                                • 3008
                                #60
                                I've just got hold of this kit as well, its part made up to planking the hull. I'm daunted by the work I will have to put in !!!! Oh well one day I'll get round to it I guess
                                Adrian
