I started on my WTC today. I’m using a Subtech motor-belt gear setup and I fitted that today and I made a bracket for the 2 servos from square plastic tube and flat ABS sheet. It also supports the belt drive. The servos run the rudder and dive planes. The speedie also goes in the back section and the APC. The air pump goes in the middle one and the battery (Li-poly) 7.4 2500mah and receiver and regulater go in the front one. The 2 front parts are adjoined for air pressure storage and the aft one is separate to avoid positive pressure on the Subtech seals from the inside when the bladder is empty.
