check this out!
  • MORIARTY1177
    • Jul 2011
    • 485
    check this out!
    Hi all, am in the early stages of planning a 1/144 u-boat dio and found this rather amazing image on the internet doohickie and thought I should post it as I've found it rather inspiring. I'm sure you may well have seen it but posting it anyway.
    P.s. any tips on how to make water look that good would be much appreciated.
    Regards
    Chris
    [ATTACH]39714.vB[/ATTACH]
    [ATTACH]43516.IPB[/ATTACH]
    Thanks for sharing Chris - don't you just hate talented people. Cheers Derek
      That's a little bit amazing!
        • 18286
        That is quite an impressive scene. One thing struck me though. The sea is rough and the run off's are spewing water, there is foam on that big wave.
        The U-boat looks totally dry. I would of thought that there would of been some wash and foamy bits and a wet boat would be at least a bit shiny.
        Nether the less it is still impressive!
        As to making the water, there are as many ways of doing that as there is of cooking potatoes! Some are easier than others. Getting it to look good is the hard part. Its a trial and error thing.
        One simple and effective way is make a base out of what ever you normally would. Plaster, expanded polystyrene, what ever, just to get the wave tops and the swell. When that is totally dry scrunch up some cooking foil a bit and then glue that on top. I would suggest the dull side up. Use pva wood glue and paint the top with it as well.
        When that has dried its the challenge of painting. I would thing that fairly translucent colours in loads of coats. This will give the surface depth. The last couple of coats should be almost clear.
        Where you want the foamy bits you can add white. As for the actual foam on top, its either white paint or a bottle of vallejo's foam/snow effect.
        The process is slow and gets better with practise. If I was you I would try a couple of small ones without the kit, just a base to figure it out.
        • tiking
          • Jul 2006
          • 1697
          WOW!!!! Very impressive. I admire water effects.
