Under Construction...1/350 Airfix H.M.S. Triumph...Nuclear submarine
  • spanner570
    • 15594
    I've just finished this, but here are the build pictures, prior to adding the silicone.
    I only needed the upper hull and I dispensed with most of the periscope gear etc.....So I was left with a grand total of nine pieces to glue together!!
    [ATTACH]80819.IPB[/ATTACH]
    [ATTACH]80820.IPB[/ATTACH]
    [ATTACH]80821.IPB[/ATTACH]
    [ATTACH]80822.IPB[/ATTACH]
    [ATTACH]80823.IPB[/ATTACH]
    [ATTACH]80824.IPB[/ATTACH]
    Photos 2 and 3 are obviously the wrong way around........
    The first stage was the kit construction and painting.
    Then I fitted the hull into some polystyrene
    Then a layer of tile adhesive.
    A layer of polyfilla was applied to form the basic waves, ready for the silicone
    Then, as you know, I always use cheap acrylic paints to cover large areas such as the sea. This I built up with various shades of blue/ green....
    I intended to put this writing between the pictures, but couldn't figure how to!
    Ron
    • 18286
    Nice one Ron. Simple and effective.
    • spanner570
      • 15594
      Originally posted by \
      Nice one Ron. Simple and effective.Ian M
      Thanks Ian, I've now added the silicone and took pictures of the finished boat, so I'll post them in 'Completed' soon.
      Ron
      • PaulTRose
        • Jun 2013
        • 6820
        • Tattooine
        i like how thats going
        Per Ardua
        • spanner570
          • 15594
          Thanks Paul, Glad you like the progress.....a bit short and sweet, but a challenge nonetheless.....
          Ron
          • flyjoe180
            • Jan 2012
            • 12658
            • Joe
            • Earth
            Nice work Ron
              • 22851
              Looks like another classic Ron build in the making
              Ron to write inbetween the pictures, after you have uploaded them put the curser ( pulsing stick thing ) behind the picture you wish to write infront of then as you write the piture moves forward infornt of the words
              • spanner570
                • 15594
                Thanks for your post Joe and also thanks Ian for your information. I appreciate it.....
                I've added the silicone and finished the submarine. The pictures are in Ships and Boats - Completed Submarines.
                Thanks to everyone for your input during the rather rapid construction!
                Ron
                • monica
                  • Oct 2013
                  • 15169
                  great build Ron, i do like how you turn plaster into water, with paint and silicon well done
