This has two advantages (at least for me): first, it is a gel so stays put (although the usual more liquid type has its uses); and second: it is fitted with a nozzle which allows a tiny amount of glue to emerge and easily applied either by dabbing the nozzle on the part, by dabbing the part on the nozzle, or via a toothpick. I have been annoyed for years by bottles of the liquid version with a nozzle that spurts out and have needed to use a dipped toothpick with those. It sets in about a 30 secs or less (as indicated by "short-term correctable"), so is not lighting fast but there is a greater chance that, the glue being a gel, the part will sit by itself without moving until the glue sets if the model is held in such a position that gravity does not move the part. I got it from my Tesco convenience corner shop
For those new to superglue, be very careful not to get it where it should not be, such as you hands, or on your eyelids! Superglue is said to set faster if the surrounding air is moist, so I often breathe out slowly and gently on it.
EDIT: another hint. I find that superglue will not set if more than is needed to make the joint is applied. Use very tiny amounts,
