I had a difficult job trying to mask the bomber’s nose on a Mosquito 1/48 which is oval. Had to be right as it is the first thing you see, the nose of the model. One problem is that the masking line is oval but also the nose piece is rounded as a marble. IE you are negotiating the tape on differing planes.
Tried Tamiya Tape cut to a very thin width of .5mm. Tried stretching as I applied the tape but always got crinkles at intervals around inside edge (the paint edge) This is the oval shape of the frame separating the flat piece from the rounded oval area. Cut the crinkled parts so they overlapped & burnished down but the paint result was horrible. Washed the whole lot off.
Eventually used some vinyl tape
Vinyl Masking - Model Boats
Negotiated the oval shape with a piece of this vinyl tape on each side of the oval. Slightly stretching as applying. Used the .5mm width tape & the tape is very thin which is probably why it can negotiate curves well. No crinkly bits as the Tamiya Tape. Burnished although I doubt it needed it. Applied 2 coats of acrylic paint by hand brush & removed vinyl tape after 30 mins & the result was perfect . Not a sign of any paint creep at all or the paint pulling away with the tape. No need for any remedial attention.
Think that perhaps the paint sticks in the minute pores of the Tamiya tape whereas it cannot with the vinyl. Also the vinyl tape stuck fast where already fixed when stretching but find the Tamiya tape moves. The vinyl is much easier to cut.
The vinyl being transparent has advantages & disadvantages. You can see if you have overlapped a frame line. But it is more difficult to see the vinyl edge compared to Tamiya Tape. You do need a magnifier of some sort & good lighting. But the disadvantages do outway the results which is what counts.
Widths sizes in the pack I have - 0.5mm , 1mm , 1.5mm , 2mm , 2.5mm , 3mm , 4mm & 5mm. More than 4 metres of each width so just about a life times use for canopies etc.
