Special Hobby 1/48 EoN Eton TX.1/SG-38 Inbox Review
    I'm suffering from builders' block at the moment, so I thought I'd review one of the more oddball models in the stash
    Wingspan 220mm, length 130mm.
    Comes in a rather flimsy end opening box...............
ID:	1168124Click image for larger version
ID:	1168125Click image for larger version
ID:	1168126Click image for larger version
ID:	1168127Click image for larger version
ID:	1168128Click image for larger version
    Instructions - A5 colour booklet - looks pretty good, but will require careful study!
    One sprue onlyClick image for larger version
    Decals - mostly for the UK air cadets schemes!
    .....................and a tiny PE fretClick image for larger version
    I'll be posting detail shots & comments momentarily!
    Some detail shots
ID:	1168135Click image for larger version
    This is a short run kit, detail is good, but you do have flash, so careful clean up will be needed
ID:	1168136Click image for larger version
    Wings & tail have some nice rib details, may be overdone, but should take a wash nicely.
    There are some very fine partsClick image for larger version
ID:	1168137Click image for larger version
    Quite large ingates means careful removal.
    And to the nasty bit!
ID:	1168139Click image for larger version
    The difficult part of this will be the rigging - the instructions look clear enough, but aren't for the timid! This is a short run kit, so I have no doubt that a lot of trimming & dry fitting will be needed, so not for the beginner.
    Special Hobby also do this in 1/72 - same subjects, but I think you may be a masochist to try & build that!
    I got this off ebay for a discount ( enough for p&p ), and is widely available.
    If you find this interesting/useful, I might do some more inbox reviews of the more esoteric models in my stash, ones which I haven't seen inbox reviews for.
    Thoughts?
    Davew
    • Nicko
      • Apr 2019
      • 1622
      • Nick
      • East Anglia
      Good luck with that one Dave when you get round to it. Looks extremely fragile!
      Nick
      • minitnkr
        • 7785
        • Dayton, OH USA
        Would make an impressive model completed.
        • rtfoe
          • 9208
          • Richard
          • Shah Alam, Malaysia
          Looks interesting Dave and only requires that all align at 90 degrees. The PE should be easily attached and looks like its frame fasteners just like the real thing with bolts already in place.
            • 19102
            Interesting subject Dave. Detail looks good, but mould lines are quite prominent on such delicate parts so clean up will be time consuming…will be lovely when it’s built though.
