WEST MOUNTAIN RADIO-CBA Computerised Battery Analyzer.
  • John
    • Mar 2004
    • 4667
    • John
    • Halifax
    #16
    (Will post better picture when 'Photobucket' site is working)
    You could also use the gallery to post your pictures
    www.scalemodelshop.co.uk
      Mike,thx for info. I've taken the plunge and bought one, arrived this morning!
      I've done some quick tests and the results are startling; in particular some new matched & zapped cells I bought on the recommendation of a friend, seem to be c**p..... will try cycling them a few times and see if they improve.
      Well pleased with CBA though, looks to be an indispensable piece of kit :respect1:
      Paul
      I am pleased obviously with your response, if you need any help in the interpretation of your results do not hesitate to contact us.
        Thanks to results obtained from CBA I've binned 2 packs, sold 2 new *matched* packs, and bought some new cells to replace them.
        It's fascinating trying different charging methods and then being able to plot discharge curves to compare results. I discovered by accident that my charger has a form of 'burp' charging on it so was able to try this out and see the different effects this had on Nicads & Nimhs, very valuable.
        Mike, it says in the instructions that there is a device available to connect the CBA to individual cells do you stock this, and can it be used on an assembled saddle pack? Want to try and weed out any weak cells in existing packs.
        Regards Paul.
          Regards Paul.
          Paul are you referring to the powerpole connectors.Glad you are gettting the benefit from the unit.
          Sorry for the delay in my reply
          Regards
          Mike
