MIG productions MUD...A review.
  • spanner570
    • 15599
    John kindly sent me two tubs of MIG MUD and asked that I post a review of the results, this is a report on my findings........
    I was sent one one of each - European Dry Mud (Rough texture) and Sub Sahara Wet Mud (Fine texture)
    This review is of the Sub Sahara....The European I will use on a vignette and post when finished, but obviously it's the same product, but different colour and texture.
    So what do you get in the 70mm x 35mm plastic tub?
    75ml of mud. One screw on lid, that hides a tight, push fit insert with a nice little pull tab to pull the thing out with...this keeps the mud fresh for future use.
    The actual mud is a resin based mastic type substance. There are no instructions on the tub, other than suggesting you go on the MIG website for more info - I did this but could only find pictures! So, right or wrong, I gave the mud a bit of a stir.
    Application.
    The use of rubber gloves is recommended in the product pictures. I didn't bother and what little that ended up on my fingers was soon removed with warm water.
    Using an old paint brush, I applied the mud to my sealed base. No need to colour the base prior to applying the mud, it more than covers anything! Once spread, I worked it into the shape I wanted. For the finer detail I used a cocktail stick dipped in water - this stops the mud clinging to the stick....Although it goes on semi runny, it can be built up quite high particularily around the tyres and doesn't collapse into a wet lump, but holds it's detail really well.
    I experimented with it and made all sorts of tracks, thick , thin, deep, trying to get it to misbehave, but it kept it's shape throughout.
    When first applied it looked far too shiny, but as it dried it dulled down.....
    At first, due to lack of instructions, I was concerned about the drying time, but as it turned out it took 3 hours to set, so no need to hurry. Although I did notice it took considerably longer where I stacked it up. Once dried it is rock hard.
    Coverage.
    Obviously this depends what sort of diorama - thick or thin mud - I used roughly half the tub on an area 25cm x 10cm creating varying thicknesses.
    Conclusion.
    It holds whatever shape you throw at it, and with a small brush or cocktail stick quite intricate shapes and detail can be achieved, also it has more than enough working time. The push in insert should ensure the mud has a good shelf life once opened.
    An excellent product from MIG.
    The pictures show the two colours - the light colour is the European and the dark is the Sub Sahara - the tub insert - then the mud is when first applied and the last shots show the mud fully cured - sorry for the slightly blurred last shots.
    Thanks again to John for entrusting me with a review.
    Ron
    [ATTACH]61289.IPB[/ATTACH]
    [ATTACH]61290.IPB[/ATTACH]
    [ATTACH]61291.IPB[/ATTACH]
    [ATTACH]61292.IPB[/ATTACH]
    [ATTACH]61293.IPB[/ATTACH]
    [ATTACH]61294.IPB[/ATTACH]
    [ATTACH]61295.IPB[/ATTACH]
    [ATTACH]61296.IPB[/ATTACH]
    [ATTACH]61297.IPB[/ATTACH]
    [ATTACH]61298.IPB[/ATTACH]
  • spanner570
    • 15599
    Here is the other MIG MUD John kindly sent me to do a review of.
    This one is P501 European Dry Mud (rough texture) On first opening the tub I was surprised just how light the colour was, and had my doubts about the finished shade, but it dried to a lot darker colour.
    For spreading it on I used the same method as with the earlier sample. This one is very gritty, hence the rough texture, but is just as easy to apply.
    The product isn't cheap, and to get decent imprints of tank tracks and the like. it has to be put on quite thick. For this last sample I used the whole tub spread thinly on an area about 25cm X 12cm and only put it on thickish in one thin strip to show a bit of a tank track impression.
    In concluding the review of the two excellent samples, I found them easy to apply and mould to around 3mm thick without the stuff collapsing. They dry rock hard and can be painted if required, and would be ideal for modellers who want an easy to use, ready coloured, instant mud.
    Thanks John for entrusting me with the reviews.....There are other shades and textures of MIG MUD in John's shop , so do have a look.
    Here are a few pictures of the mud surrounding my 1/35 'Dead Elefant'
    Ron
    [ATTACH]62172.IPB[/ATTACH]
    [ATTACH]62173.IPB[/ATTACH]
    [ATTACH]62174.IPB[/ATTACH]
    [ATTACH]62175.IPB[/ATTACH]
    [ATTACH]62176.IPB[/ATTACH]
    [ATTACH]62177.IPB[/ATTACH]
    [ATTACH]62178.IPB[/ATTACH]
    [ATTACH]62179.IPB[/ATTACH]
    [ATTACH]62180.IPB[/ATTACH]
    [ATTACH]62181.IPB[/ATTACH]
      • 22954
      Thanks for the reviews Ron the mud looks very real and doe's the trick
      • John
        • Mar 2004
        • 4698
        • John
        • Halifax
        Nice review Ron, does the wet look dry out or stay looking wet?
        www.scalemodelshop.co.uk
