Cleaning my airbrush after using Johnsons Floor Wax (Klear)
    I have had a search through the "Airbrush" section of the forum and I'm looking for some info regarding what liquid to use, to clean my airbrush after using Johnson's/Pledge Wax Floor cleaner (Klear).
    I normally use Screen Wash etc to clean my AB after using my Vallejo paints etc. But I recently used the Floor Wax on my U-Boot model, through a cheapo AB that came with my compressor.
    The AB seemed to be in proper working order whilst I was using the wax, but as It was my back up AB, I forgot to clean it out.
    It seems now, that the wax has coated the inside of the AB. I went to use it over the weekend and it barely spat out anything.
    I'm not trying to get rid of this hardened wax, but I would like to know what I should/could use to clean my other back up AB, once I have used the wax?
    Will a normal AB cleaner fluid do, or would I need to use White Spirits or Cellulous thinners?
    Any help is appreciated.
  • john i am
    • Apr 2012
    • 4019
    I would imagine a total strip down a soak in airbrush cleaner a poke around with a dental brush should restore your brush to normal working order.
      Normally, anything containing ammonia would work - Windex etc.
      On dried-out Klear ... as John said, a full stripdown & clean is best. If it were me, I'd use cellulose thinners - that clears everything! However, if your AB isn't ok with something that hot, steer clear because it'll damage the seals.
        Yeah, I was/am a bit wary of using cellulose thinners on my AB's.
        It was/is only a cheapo AB that I had used, so may give it a full strip down anyway.
        Thanks
        • ojays
          • Oct 2011
          • 1713
          If it has Teflon seals, Cellulose thinner is ok. But don't use if they are rubber seals.
          Gregg
            • 18302
            To soften the dried up Klear drop it in a little jar of....... Klear for a while as it dissolves its self. Then clean with anything that contains ammonia.
