H&S ultra new airbrush
    today was the first day i used the new airbrush.
    After using the iwata Neo (not an Iwata actually, more of the chinese AB style) and a few chinese ones, the H&S ultra is a little different and takes a few tries to adjust to.
    The feel is similar to all the airbrushes, the trigger is what i thought was less responsive, but the more ive used it, the more i feel its more refined, allowing you to move the trigger back with more scope than the neo. The amount of adjustment in moving the trigger back is finer, allowing me to adjust the paint much better than the lesser ABs, which work ok, but have less regulation on the trigger pull.
    The biggest difference is in the mechanics, particularly the nozzle.
    The chinese ABs and Neo all have a screw in tip, whereas the H&S ultra has a floating tip, requiring the nozzle cap to be done up correctly. This was apparent when i first used the AB, and had bubbles entering the paint cup!
    I honestly thought something was wrong with the AB, and had inadvertently been shipped a duff AB.
    But, its simply a case of making sure that nozzle cap is tight, it seemed ok but a slight tweak tighter and the problem is rectified.
    I have the standard .2 needle/tip fitted, as its the Ultra not the two in one, and ive found it works fine for my needs, the spray pattern further away seems big enough to cover larger areas ok, and the fine line control close up is very good. Probably wont bother getting the .4 set to be honest.
    The only thing about the nozzle cap i find a little harder to use is the fact it has side holes. Not sure what they are for, but when cleaning, i like to backwash the AB to clear it, and its very much harder to do, although not impossible.
    So, very happy with the airbrush and its performance, and with the quick disconnect means i can keep the cheap chinese ABs with .3 and one with .5 needle/tips for varnish and primer respectively.
    By the way, if anyone knows why the nozzle tips have those holes please let me know, as i dont understand that part.
    The Ultra is definitely a lovely airbrush - since I junked my old Chinese AB I've been enjoying painting much more.
    I've no idea what purpose the holes in the nozzle cap serve, unless it's to aid the paint/air mixing?
    • stona
      • Jul 2008
      • 9889
      I know that some get on quite well with the cheaper Chinese brushes etc but you now have a quality tool. I think you are finding for yourself what a difference that makes. 'More refined' sums it up quite nicely. Basically all the parts of your new airbrush are made from better quality materials and are manufactured to higher standards.
      I've got no connection with any airbrush company but another point to consider is what happens if something does go wrong with your airbrush. All the higher end products have proper guarantees and there are places you can get them serviced if you can't fix a problem yourself. Parts are also readily available. I've just bought a new nozzle for one of my Iwatas, not cheap at 20 quid, but a lot less than a replacement airbrush. Cheaper brushes are essentially disposable items and you won't get any kind of guarantee or other back up.
      Just saying
        I agree, and while i have a couple of those chinese ABs, and theyre still working, ill use them for the primer etc. Saves me having to buy the .4 needle combo for the H&S
        • PhilJ
          • May 2015
          • 1145
          Glad the new airbrush is working out for you Dave, as others have said you have a bit of quality there now and I'm sure it will pay off. I have the silverlive Evo and it's a great tool.
          Now have my eyes on the Iwata HP-CH and giving my H&S to priming alclad duties but that is going to make a dent in the pocket before xmas.
          Enjoy
          • Adrian "Marvel" Reynolds
            • Apr 2012
            • 3008
            Just a stab in the dark but would the holes allow you to work closer to your subject by allowing air out that way rather than forward onto your work?
            I use a crown on my AB to allow close work in much the same way.
            Adrian
              Adrian
              That's a good shout Adrian - I think you've cracked it!
                Aha!
                Ok, makes sense!!
