'Holdie' things
  • Steve Brodie
    • Sep 2014
    • 4652
    'Holdie' things
    Howdy,
    What do people use to hold parts whilst they are been sprayed, have been thinking of wooden dowel, with the parts attached using white glue on the side not to be seen, not sure what though for where both sides will be in view, dont want white glue to have to remove . Or Sprue, with normal glue / white glue / bluetack never seems to stick very well though
    Blu tak works better if warmed a little Steve, but it does have its limitations.
    For parts that have a non visible face, I stick it on a barbecue skewer with superglue. The skewers are better than toothpicks, being longer. Usually I'll drill a small hole for the tip of the skewer.
    I've also used wooden lolly sticks, usually for figures. Superglue a boot heel to the stick, and all areas of figure can be reached.
    Tweezers can be used too, with a clothes peg keeping them closed. Watch out for parts pinging off into the distance though!
    • eddiesolo
      • Jul 2013
      • 11193
      I use blue tack/white tack, and also, the the piece is large some weighted crocodile clip holders with some foam stuck the grips.
      They are like this, I got them from a charity shop for 50p
      • PaulTRose
        • Jun 2013
        • 6820
        • Tattooine
        all depends on what needs to be held
        toothpics and bbq skewers with blobs of blutac or pushed into suitable holes..............ive got a couple of bits of wood with holes drilled in (like a cribbage board) to put them in to hold them upright
        if im doing car bodies i have a wire coat hanger bent into a vee with another bent bit at the end......the natural spring out pushes against the inside of the car bodies...makes a 'handle'
        Per Ardua
        • Steve Brodie
          • Sep 2014
          • 4652
          Thanks everyone
          • Gwyn
            • Dec 2015
            • 399
            Similar to Si I use small dowel to which I have fitted little crocodile clip which can be bought for pennies on the internet. I then have a wooden plock with suitably sized holes drilled in it so that i can insert the dowel. It works well.
