Tamiya releasing new paint range
  • BarryW
    • Jul 2011
    • 6142
    #16
    Originally posted by Stevekir
    I have read BarryW's review, (http://www.scale-models.co.uk/thread...-review.28812/) but I still can't see any difference from use point of view of these paints. Barry says that the MRP range is compatible with "Tamiya paints using a laquer/alcohol based solvent", which I assume means Tamiya's TS range. His report states that the MRP range is (a) very thin, (b) includes metalizers which I don't think are in the TS range, and (c) some additional colours. Is that all?.
    Surely Tamiya would not have launched a new range of solvent-based paints which give the same results as their TS range apart from the above three differences.
    The amazon bottle shaker costs £30.99
    Hi Steve
    Sorry but I am not quite sure exactly what you are saying, I am a bit confused.
    MRP are undeed very thin, almost an ink-like consistency ready to spray, dry quickly to a satin finish and are very forgiving. They are laquer based and are compatable with i.p.a. which can be used for clean-up. These are close in formulation to Gunze Mr Color laquer paints but the Gunze do need thinning for the airbrush unlike the MRP..
    The Tamiya paints are thinned with i.p.a. not water and are also compatable with laquer thinners. From what I read the new range are the other way around, laquer based but possibly compatable with i.p.a for clean up. Making them even more like the MRP range.
    All of these of course are distinctly different to the water based ranges such as Vallejo as i.p.a. can really clog up these paints if you try thinning with it. i.p.a. does have its uses with these of course and it is good for cleaning off dried paint (as is laquer).
    Totally incompatable with the above of course are enamels which are unaffected by i.p.a. (not tried laquer on them...) Enamels are very good as weathering products applied over the above due to that incompatabiulity.
    As for why Tamiya have brought out a laquer based range, I really dont know. I note that Hataka and AK Interactive are also doing the same thing.... Perhaps they are responding to the success of MRP laquers ....
    Mind you MRP are also bringing out a range of water based acrylics as well, mirroring the colours of the laquer... I can see a lot of sense for them in this as the water based can be used alongside the laquer for easy brush touch ups etc.
    The wonderful world of paint gets ever more complex with more and more choice....
    • BarryW
      • Jul 2011
      • 6142
      #17
      Originally posted by Tony
      Well at least the price is acceptable so will be interested to try out a couple to see what they are like.
      At £1.99 it makes them more expensive than MRP which have 30ml bottles making the new Tammy £0.98 per 30mls more expensive though I dont know yet if they need thinning for the airbrush or what the ratio is if they do, if they do then they may work out a bit cheaper though they will need thinning with something like Mr Levelling Thinner which is a bit costly itself. I suspect there is not much difference in the overall costs.
        Thanks Barry.
