I have one of these airbrushes and it’s a good bit of kit, but I’ve developed a problem with it where it isn’t drawing the paint out of the cup when I try and use it.
When the paint is drawn down, it isn’t a a consistent spray pattern which is produced, but instead there are “large” blotches which get sprayed everywhere with little to no control.
I have stripped the guns down to individual components and cleaned them as best as I can and there is no obvious remnants of paint on the inside that I can see.
I’m operating it at a fairly low pressure - 1.5 bar (21 psi) - and I’ve tried adjusting the pressure to see if this helps but, alas, no.
Are there any tips or pieces of advice anyone could provide to me about where I can get a new set of o-rings/seals to see if this can alleviate the problem or just something that I am missing.
